Lorentz force questions
Started by aladinlamp, December 22, 2012, 08:51:36 AM
gravityblock
The Lorentz force is nothing more than the Z-D force1 viewed from the proper inertial system of a permanent magnet.  The field of a permanent magnet is magneto-static. The movement of the magnetic source causes the Z-D effect which has been termed magneto-kinematic.  A magneto-static field does not meet the requirement for wave motion and moves like a body synchronously with its source. Nevertheless, the magnetic field satisfies Faraday's law just like any electromagnetic wave.
1.)  Zajev-Dokuchajev (Z-D) effect: the moving of the magnetic field with the rotating magnet.
Gravock
gravityblock
The comments found in the image below are so true when you really think about it as shown by the work found in Section 5.  Experiment #3 is an instance of Faraday's Law due to the strength of the magnetic field changing.  However, the magnetic field itself in experiment #1 and #2 are not changing, thus it is not an instance of Faraday's Law.  This is an important and fundamental aspect of electromagnetism in which researchers need to understand.
Gravock
gravityblock
The phase shift cannot be explained if the magnetic field is considered to be immobile, but is readily explained by the rotation of the magnetic field with the magnet.
Gravock
gravityblock
There is a new method of calculation presented in the publication which is applicable to a range of generic problems dealing with moving sources of magnetic flux.  This is an important and fundamental aspect of electromagnetism which needs to be understood.  Due to the lack of response, it appears the significance of this is being overlooked.
Gravock
Quote from: gravityblock on May 01, 2013, 04:32:46 PM
Don't mistake silence with absence ;) .
A custom made half moon neo magnet.
