1850 Watts free energy power ? New GEGENE circuit by JL Naudin shows COP = 2.8
Started by hartiberlin, December 29, 2012, 08:16:11 PM
hartiberlin
Hmm,
thzanks tagor and TK for the explanations.
Pretty strange circuit !
Why don´t they not just use some kind of Joule Ringer circuit, where you
can set the pulse frequency of some positive pulses ?
WHy do they need the 50 Hz Amplitude modulation at all ?
I still don´t understand why the aluminium cooler plate for the IGBT is not affected
by the eddy currents or also the circuit board in the cooker ?
Is it too fra away from the coil ?
Is it just a magnetic heating effect only, so you need to have real ferromagnetic material,
as the frequency is too low with about 20 Khz ?
Hmm,
what do you think of the latest Power measurements from Naudin.
If you optically integrate the areas under the envelopes and spikes, it seems
that he has more than 2000 Watts output with less input...
But can we trust these measurements ?
The true solution would really be using charged supercaps or el. caps
running an inverter and powering the cooker plate with it and then
use the bifilar output coil to bridge rectify the output and charge up
the caps and see, if this will loop indefinately or the cap charge will run down ?
I guess it will run down, but you never will know...
Regards, Stefan.
fritz
... the modulation seen in the traces is just a fragment of the overall modulation.
The used trigger method /  horizontal deflection / holdoff shows a periodic picture of an a- oder pseudo periodic event - which cannot be used to extrapolate the overall efficiency.
rgds.
I think the Joule heating of the coffeepot is the best output power measurement he's made so far. There is not much that can go wrong with the method the way he did it.
tagor
Quote from: TinselKoala on January 06, 2013, 05:24:48 PM
ok the pdf is a good answer
JLN is doing a lot of measurement , wait and see
for the circuit it is not "a good solution" it is the cheapest one
tagor
JLN is doing a lot of measurements with only one envelope and
all those measurements are with the same cop ...
but if the envelope is varying all the time he need to take in count
a lot of envelope this is the big problem with the data
