1850 Watts free energy power ? New GEGENE circuit by JL Naudin shows COP = 2.8
Started by hartiberlin, December 29, 2012, 08:16:11 PM
mikestocks2006
Quote from: TinselKoala on January 08, 2013, 01:12:52 PM
Why oh why do people insist on using the "box label" on a device as the "output power" no matter "watt" ? If a light bulb says "500 Watts" on it, that does NOT mean that it will always dissipate 500 Watts !! This is its rated power dissipation when it is supplied with its rated voltage from a source capable of supplying the necessary current so that the voltage doesn't sag. Just because there are 1800 watts of bulbs connected to the circuit and glowing, that does not mean that the circuit is dissipating 1800 Watts !!
Jean-Louis surely knows this.
I am watching this thread and his videos with great amusement. The chances of self-looping are nil. The output power available is less than the input power and he's already confirmed this by two independent sets of measurements: the rough calorimetry, which could NOT be in error by enough to invalidate his results, and also the photometry of the light output.
Exactly!
If it really produces a true 2.8 out for every 1 in then a looping self-runner should be no problem, (conversion efficiencies included), and it will be the ultimate proof.
Great thread/info/links
Thanks
Mike
hartiberlin
Hmm,
http://jnaudin.free.fr/gegene/gegene13en.htm
we see, that he uses about 750 Watts from the grid,
but his whole unit needs 990 Watts to run.
So who is supplying the EXTRA 240 Watts ?
Or are the lights bulbs only as bright.
as if really only 750 Watts would be fed into the whole system ???
Hmm...confusing...
As the Kettle water cooker and the light comparison have shown, the system seems to be underunity,
but this new test is baffling again... hmm...
Regards, Stefan.
gotoluc
I don't know why now so many are interested in JLN last video as if he came up with this idea.  The exact same test was done 5 days ago by Romero UK and almost no one commented.
Jan. 3rd Post: http://www.overunity.com/13228/1850-watts-free-energy-power-new-gegene-circuit-by-jl-naudin-shows-cop-2-8/msg349857/#msg349857
Romero UK video: http://www.youtube.com/watch?v=H8_zj4cRXYk&feature=em-uploademail
hartiberlin
yes Romero did the same test but it even was more confusing cause he never posted a circuit diagram and not everybody knows how a grid tie inverter works.....
so is this just some kind of bootstrap effect with the second power meter showing wrong values or why does it show 240 watts more input power ??
Cherryman
What i don't really understand is the fact that JLN has an excellent track record of the most complicated tests and reproductions , with very complicated systems and measurements..
Then he vanishes for a long while ...
And returns with this... stating a bold conclusion.. based on the output of the brightness ...
Am I the only one who find it a little strange..?
He should (or does) know better..
Unless he is trying to tell us something between the lines....
