I have a working free energy device
Started by one_christian_warrior, January 05, 2013, 03:20:51 PM
This is the same old "overunity wheelchair" poster that started this thread in January 2013. Nothing new except more Bible stuff.
http://www.overunity.com/13236/i-have-a-working-free-energy-device/msg350093/#msg350093
that_prophet
the workings of this machine are beautifully simple
you only put enough power into the DC drive motor for one rotation,
this drive motor is connected to a very large pulley
so that you get the largest circumference you can get
to be sure you go through plenty of distance on the belt, cord, rope
that you are using to connect all of your pulleys
then you gain more of a multiplacation factor by using miniture pulleys on your output generators
as the smaller the pulley on your output generator
the more rotations you get +
the more rotations, the more AC electricity that you generate
Quote from: TinselKoala on April 17, 2014, 04:26:15 PM
that_prophet
I neither create nor destroy
I merely convert the multiplication of pulley rotations
into electricity = AC power
Quote from: memoryman on April 17, 2014, 03:34:22 PM
energy can neither be created nor destroyed. If you can demonstrate otherwise, you deserve a Nobel prize.
Energy multiplication/magnification is equivalent to creation, so that can not be done either.
All you do is increase the speed and simultaneously decreased the torque, resulting in the same power (minus the losses).
Pirate88179
Quote from: that_prophet on April 17, 2014, 08:58:10 PM
The effects of different sized pulleys, like gears, is well known.  No free energy here....sorry.  Why do you keep making these same topics?
Marsing
The problem is, if you get a multiplication ie. speed, you will get Distribution of torque and reverse, you can not get both amplification at the same time, it depends on your configuration,
you need to introduce something.
