I have a working free energy device
Started by one_christian_warrior, January 05, 2013, 03:20:51 PM
that_prophet
I use pulleys to multiply rotations,(AC power)
the torque is not a problem
torque is minimum on the turning of the large pulley
Quote from: Marsing on April 17, 2014, 10:03:43 PM
The problem is, if you get a multiplication ie. speed, you will get Distribution of torque and reverse, you can not get both amplification at the same time, it depends on your configuration,
you need to introduce something.
memoryman
You either have OU (more energy out than in) or you don't.
If you do, demonstrate that. The excess energy cannot be created, so where does it come from? Only conversion from another form or matter conversion. Which is it?
Marsing
Quote from: that_prophet on April 17, 2014, 10:17:07 PM
Yes, with that config there will more rotations,
but you will need to multiply torque in big flywheel.  torque is a really problem.
if you do proper math to find the correlation of pulleys and flywheel. you will find what i mean.
that_prophet
Quote from: Marsing on April 17, 2014, 10:40:39 PM
it only takes a slight amount of torque
to rotate a large pully
What this Christian Warrior is trying to get out to the world,
is the simplicity of tHis Gift.
Free Energy is here + now, even free of all patent fees =
please Goggle free_energy + yolasie.  http://free_energy.yolasite.com/
free energy can be made simple,
you can use pulleys to multiply your electricity
instead of using oil to generate it
but no one will listen to the simplicity of it
all you do is put power into a motor to turn a large pulley only one revolution
and then you get massive amounts of electricity back
from the many small pulleys attached in the same belt
Please realize the dark conspiracy covering this subject, yes this is dirt simple, almost too simple to work,,, yet it does indeed work, you just need the faith to try it. Seriously, just try it out, and you will get to see the workings of one of His Miracles. Please, don't let this miracle be hidden any longer. Let us start using the technology of Ezekiel to change the world for the better.
It's workings are super simple
You put power into a motor to drive a large pulley only once (little energy)
+ You get out a multiple of that electricity
Depending on how small the generator pulleys are
As well as how many generators with little pulleys attached
With the amount of belt that goes around one large rotation
You can easily get 10 – 20 times the rotations of the input pulley
Then you can double your rotations each time you add yet another generator
On your own belt system, (easily done – takes little torque)
I figure, you simply must gain a multiple of the energy that you put in
As you are only putting enough power into the drive motor to rotate it only once
And you get back many times the electricity
Not only having smaller pulleys,
But gaining more rotations per foot of belt that you go through
To double or tripling your rotations by adding additional generators
on their own mini-pulleys
Marsing
Quote from: that_prophet on April 17, 2014, 10:53:53 PM
Forget about conspiracy for a while.
now you add more ac motor,
do little experiment,
you will find that you will need more torque to turn the big wheel,
adding more ac motor, more torque will be needed to turn big wheel.
