I have a working free energy device
Started by one_christian_warrior, January 05, 2013, 03:20:51 PM
ATOM1
hahah ok a free energy mobility chair hahah why not !
I have a zero point motor for that if you are willing to build it in to your chair ???? It never runs out of energy !
ATOM1
Low-Q
Quote from: sm0ky2 on July 01, 2015, 05:54:28 AM
momentum is conserved when you accelerate uphill.
the wheelchair uses less electrical energy when traveling quickly than it does when struggling to go uphill very slow.
for the same reason it is easier for you to run uphill than to walk.
as far as the trip down, to properly test what you are saying, you need a controlled environment and accurate measurements of your speed.
M = m * v, a small change in speed can create a great change in momentum, which results in a higher uphill roll.
As far as the trip down goes, I perfectly know how to RUN downhill. It ends up with gravel and goat droppings in my mouth. Definitely not OU....
And if you bicycle downhill, on a bumby road, the steering lives its own life for a short moment before you perform a massive faceplant...Not OU.
I wouldn't dare using a wheelchair downhill - too dangerous.
Vidar
ATOM1
I DNT SEE HE HAS AN OPTION ! and like the I can do it approach a proactive mind is a healthy one .. Now lets see about the free energy mobility system mmmmmmmm ok I now have 9 options ... stating from £2000 up to £100 000 but that one is a E formula 1 FREE ENERGY racing mobility something ! R u ok with say 400 mph ???
Atom 1
that_prophet
Quote from: that_prophet on April 22, 2015, 04:16:06 PM
"You either have OU (more energy out than in) or you don't."
I have used pulleys to multiply the # of rotations,
+ with AC electricity, rotations mean you can also multiply the AC electricity
By using AC electricity + adding additional pulleys to increase the total # of rotations,
Which with electricity alone, can be used to multiply you AC electricity
[/quoteThis is so simple... to build + to understand + to work with...
if you attach a 100cm circumference pulley to a DC motor
it only takes one spark of DC current to rotate a DC motor one full rotation.
this would give you 100cm of moving belt to work with
now if you run this length of moving belt past 1to10 mini-pulleys.
each having one centimeter circumference + an AC generators attached to each pulley
then you would gain a multiple of 100 to 1000 units or cycles of AC electricity.
these are free running AC generators=(as there is practically no load on them)
( you only need to generate one single spark of DC current output to power your drive motor)
(+ this is divided by 100's or 1000's of AC rotations)
all of these generators are running with zero load-(practically) = no current being used
just the fluid friction of the bearings is your only wear or load-type
but you could use magnetic bearings + have zero friction
so all of these AC generators are just winding up massive amounts of voltage
which can be used as potential = ability to do more work = available current in load
you have just made your first self powered set of running AC + DC generators
that you could tap power off of + the more mini-pulleys with AC generators attached
the greater the amount of current you should be able to do work with
(now.... don't you think that you should be able to get one spark of DC current)
( out of the 1000 units-(sparks) of AC electricity that you have for an output)
( these generators are running free + give little to no resistance to rotating)
( this would make this unit a self powered set of generators) = perpetual motion +
(+ this could be producing an unknown amount of AC + DC electricity for you)
http://free-energy.yolasite.com/ = PUBLISHED IN THE EARLY 2000's
(YET THERE IS SUCH A SPIRITUAL WARFARE GOING ON AGAINST IT)
((( evil spirits were hiding this tech = lies about torque being a problem )))
((( these motors/generators are running free... just winding up massive voltage)))
SORRY TO HAVE TO SAY THIS... BUT...
Now comes the bad+scary part of this awesome free energy technology discovery
You can easily see just how super simple this AC multiplication technology is to generate...
so why could not any one of the millions of above average intelligence people have discovered this
long ago... at least as soon as AC electricity was discovered.
Well I guess that there is one good thing about this being hidden... this is positive solid proof
of there being a powerful spiritual warfare going on all around us... + they are winning
I would say that these powerful evil forces were winning = if they could hide this tech from us
where only one spark of DC electricity is being used as an input to rotate a large pulley once
this large pulley consists of a 100cm circumference pulley = giving you 100cm of moving belt
which if you ran through 1 to 10 mini-pulleys = 100 to 1000 cycles of AC electricity (free running)
THAT'S 1 SPARK OF DC INPUT... BEING MULTIPLIED INTO 1000's OF CYCLES OF AC ELECTRICITY
how can you not see that with a few of these mechanism you can easily
+ cheaply multiply yourself an unlimited amount of AC electricity = (NO NEED FOR OIL)
= no need to be financing terrorists guns + explosives = ADDED BLESSING OF GOD
I happen to be Born Again-(27-11-88)-one day more or less + want this super simple tech known
FREE ENERGY = AC electricity multiplication technology using pulleys - to be known by all...
anyone could build GENNs + be nnaking nnony by adding to the local power grid
long before the first Door closes for Christ's return in the clouds by or before 2019.04
http://doorschristmustpassthrough.yolasite.com/ + http://2020-vision.yolasite.com
This technology is in the Holy Bible = in Ezekiel 1:16
where he is describing what a UFO motor looks like while it's running
so this technology will eventually lead us to anti-gravity
as well as not only speeds approaching the speed of light
but also the ability to do 1000 kph vectoring
We are warned that no one knows the day nor hour... (Mat 24:36) but it says that we will know
when it is near... near to what? maybe the door.... as we can know when it's"even at the doors"
(Mat 24:33) + I heard that in the original Greek it was worded like a command "know that it is near"
With this technology the Tribulation Saints can keep warm in our cold Canadian winters
even off the power grid. (remember the heat + light of fires would easily give away
your position visually... as well as via satellites)
notice that Doors are plural - because He is going to show up twice =
1) - Rapture = "caught up together with the in the clouds"-(I Thes 4:17)
2) - "Glorious Appearing" at end of Tribulation -(Titus  2:13)
I DO NOT KNOW IF I BE THAT PROPHET OF THE BIBLE... BUT NOBODY ELSE IS SHOWING UP
. . . ( + there are less than 3 years left before the door shuts that Christ MUST come back by ) . . .
. . . ( + He has shown me a few Biblically significant things= 'I am" + 2020 Vision + free energy) . . .
. . . . . . . . . . . . ( to find out more GOOGLE beliefstoliveby + yolasite = 30 + websites) . . . . . . . . . . . . . .
massive
Quote from: that_prophet on November 17, 2016, 06:42:42 PM
(TOTALLY CHILDISH RESPONSE = I HAVE 3 YEAR ELECTRICAL ENGINEERING TRAINING + 1 YEAR OF COPUTER GRAPHICS SPECIALIST + 2 YEARS OF INFORATION TECHNOLGY + WITH 5 POINTS NNISSING ON ONE COURSE - TO HAVE HONORS IN THE LATEST SCHOOLING THAT I HAVE HAD) = AFTER THE CLOSED HEAD INJURY
ALSO - TO GET OUT OF A NURSING HONNE AFTER A SEVERE CLOSED HEAD INJURY = WHERE I DIED TWICE + THEN WAS DECLAIRED BRAIN DEAD = THEY CUT OFF THE LIFE SUPPORT + I WAS BLESSED ENOUGH TO START BREATHING ON NNY OWN.
IN ORDER TO PROVE NNYSELF CAPABLE TO LIVE ALONE IN AN APPARTENT I LEARNED THAT I HAD TO PROVE NNYSELF  CONNPETANT-(ABOVE 85) = SO I TOOK 2 IQ TEST = SCORING 135 ON A TEST RATED ACCURATE UBTIL 120 =(+15 ) + A 165 ON A TEST RATED ACCURATE TO 145 =(+20)
HOW DO YOU EXPLAIN AWAY THE GETTING 1000 CYCLES OF AC ELECTRICITY................ ALL WITH AN INPUT OF ONE SPARK OF DC CURRENT
no electrical training teaches DC quantity as a spark or
DC electrical input into any device as a spark .
DC motors dont run on sparks .
current is measured in amps not sparks .
what was the name of the tutor , teacher , professor that taught you that?
