converting cosmic rays to electricity comparing to T.H.Moray's device
Started by yellowsnow2, January 28, 2013, 02:01:48 PM
wings
Quote from: wings on February 05, 2013, 04:27:10 PM
other interesting readings related to plasma Self-Organization
http://www.dtic.mil/cgi-bin/GetTRDoc?AD=ADP015026
http://epsppd.epfl.ch/Praha/WEB/98ICPP_W/H094PR.PDF
http://www.rrp.infim.ro/2008_60_3/43-885-898.pdf
... plasma source of life
http://www.dapla.org/pdf/Lozneanu1.pdf
Naudin .. Electrical power from the plasma ?
http://jlnlabs.online.fr/cfr/ape/apenrg.htm
and going back to the Dynatron here some explanation
http://users.tpg.com.au/users/ldbutler/NegativeResistance.htm
http://en.wikipedia.org/wiki/Negative_resistance
In early research it was noticed that arc discharge devices and some vacuum tube devices such as the dynatron exhibit negative differential resistance effects.[4]Practical and economic devices only became available with solid state technology. The typical true negative impedance circuit—the negative impedance converter – is due to John G. Linvill (1953)[5] and the popular element with negative differential resistance—the tunnel diode – is due to Leo Esaki (1958).[6]
http://www.nobelprize.org/nobel_prizes/physics/laureates/1973/esaki-lecture.pdf
yellowsnow2
Well I made a really simple Geiger tube. just a metal tube(cathode) with a copper wire (anode) with 3mm spacing like the commercial units. Mine is enclosed in a pill bottle since my alpha emitter is put inside the bottle. Starting off trying it at regular pressure. Commercial ones run about +1.4psi.
PROBLEM.  I need a 400-500v power source. My camera circuit will only charge it to 220v. Need a new idea for a simple cheap power source.  Or do I need more surface area to hold more charge.
Picture of the inside  http://i.imgur.com/eWeGTqC.jpg
Put together  (little round thing by the needle nose is my alpha emitter from a smoke detector) http://imgur.com/DZhrYL1
This posted by "Pix" is very interesting  http://www.google.com/patents/US20110188278
PARAV
Quote from: yellowsnow2 on February 09, 2013, 08:37:28 PM
Hi Yellow,
Check this giegercounter circuit     www.uzzors2k.4hv.org/index.php?page=geigercounter    I believe it utilizes a camera type circuit in it. Have a look -and good luck.
Paul
fritznien
how much power is available per square meter in cosmic rays at sea level?
how much a hundred miles up in space?
fritznien
