Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
bitRAKE
Are the frequency ratios to insure a vortex is created within the center?
Energy might not be FREE, but the universe has been building it up for billions of years - the fact that we exist means it is availble to us.
Charlie_V
There are a few tests you might be able to do.  Sorry, this might sound too mainstream  :( - but its good to experiment.
Keep the rotary switch with magnets the same, remove the coils, and pass a current through the switch (aka charge and discharge the capacitor with the switch - which I'm assuming is electrically tied to the axial).  If there are any interactions like that in a homopolar motor, this will cause the axial to spin.
If it doesn't spin, put back the coils, like in the original circuit, and repeat.  If it spins with the coils, then it MIGHT be eddy currents.  To make double sure, replace the aluminum axial with plastic and repeat.  If it does not turn without aluminum, then it is an eddy current interaction.  If it does turn, then the secondaries are interfering with the magnetic ring somehow.
OR, you could just take a measurement of the current with the magnetic ring verses without the magnetic ring.  With the ring , the current should be larger.
I think I see what Erfinder is explaining.  The ring puts a magnetic vector potential (MVP) in the conducting axial that the magnets are wrapped around.  The MVP can produce voltage if it is changing.  We typically think of these magnets as being DC - mainstream science would say this, but Erfinder has proof that they are really AC - with a perceived high frequency oscillation.  The circuit is tuned to an octave of those magnets.  When the capacitor discharges, the magnetic vector potential (I'm calling it this for lack of a better term) will increase the current in the system.  I still think that the axial spins from eddy current interactions - remember aluminum is paramagnetic - but the over all current in the system is increased.  In my mainstream-evil views, the increased current will create a larger magnetic field in the secondaries.  When the secondaries collapse, they will induce a larger voltage into the primaries and recharge the capacitor and battery.  Thus, things will run on unity like Erfinder said.  If I'm right, that would be very, very awesome.  If I'm again wrong, let me at least use some lubrication.
Yea, I'm probably going to get attacked for saying stuff like this.  It's ironic, on conventional science forums I'm attacked for being unconventional.  On these type forums, I'm attacked for being mainstream.  I suppose I'm at a happy medium... or maybe I should just stop posting all together.
Side Rant:  Ed Leedskalnin thought there were only three things: a north magnetic particle (he called them little magnets), a south magnetic particle, and the neutral matter between.  His research led him to believe there was no electricity - only magtricity.  I have a good friend who rebuilt Ed's motor and has made some amazing discoveries.
Here's his sight, http://www.coralcastlecode.com/index.html
Look at his experiments, they are pretty awesome - and yes his website looks a little cheesy haha.  I wouldn't just throw away magnetic fields just yet, even if there is something to this magnetic vector potential thingy.
Charlie_V
Oh by the way.  I have taken apart 30 or more hard drives in my life time - usually to get at their juicy bearings.  All the magnets I've ever pulled out were (according to ResinRat2's diagram) Lateral Parallel Multi-poles (always 2 poles).  They have a curved, crescent moon, shape but are not like a bent bar magnet.  I don't think you could form a closed magnetic path with hard drive magnets.  They make them like this because its easier to shield them in this arrangement.  Here's a little drawing of the HD magnet's poles.
So, if Erfinder used hard drive magnets, either he has really rare hard drives, broke them so that their poles were like bar magnets - placing them in a special arrangement, or his magnetic ring is not as closed loop as he thinks it is.  Not trying to attack you Erfinder, just pointing out how it would be hard to make a closed loop path with regular hard drive magnets.  I've seen all kinds, hard drives from the early 90's up to today.  They all have this pole configuration.  If you did have some odd ball HD magnets, could you clue us in on the brand of hard drive?
You could take a horse shoe magnet and cut them so that 4 made a closed loop - maybe?
Grumpy
Last post?
You posted on several other forums and got nothing.  You post here, get a handful of interested people, and then depart?
OK - if that is the card you wish to play then so be it.  What is - is best.
Charlie_V -  This subject is worth persuing even without a guide.  Can you contact your friend that studied Leedskalnin's work?  Perhaps he can lead us to the water where we will either sink or walk on it - or at least point the direction.  I agree that it apears that horseshoe magnet sections would work.   I do not believe that the HD magnets will cancel.  The flux direction is through the face and you will  need end-to-end to cancel in a ring.  If you have four of these, form and ring to verify this assumption.
Barbosi and others - a start would be to read what you can find online about Edward Leedskalnin (built Coral Castle), Walter Russell, and the Tesla patents that Erfinder listed.
        -Frank Edwards
orosado
Hello Erfinder,
Thank you for everything you have shared with us. It has been a great experience. Even though you have given us much, I wish you would not depart, but that is not my choice. I guess you must have your reasons for doing so.
I can understand why you may depart, probably because you know that you have given us enough so that we may start to design and eventually develop your device.
Sincerely,
Omar Rosado
Quote from: Erfinder on February 24, 2007, 09:27:03 AM
Good,
You have found the magnets, now put arrange them as I have suggested.
This will be my last post, people want to think and do what they want and I respect this.  Someone was once asked if there is a solid state device based on what I have attempted to share here, my answer is yes.  You must sincerely study and comprehend, and understand what was given in order that you may understand the solid state, as solid state takes us into the third and fourth octaves.  Our collective understanding of electricity, magnetism, is wrong but I leave this for you all to discover for yourselves.  I have been told that I speak in riddles, this is not my intention, it is next to impossible to share what I have awakened to with people who are not willing to open their minds to newer and better things.  I wish all of you the best, and leave you all with your understandings, and the tip of the iceberg of mine, I leave all of you with an image of true solid state, where only an understanding of natures forces Paramagnetism (EMF), and Diamagnetism (BEMF), coils, and magnets are the only tools required to tap into the unlimited power of the universe.  Soon we will understand and use this untapped power source and will be enabled to fulfil our greatest dreams.  The day we collectively master diamagnetism (BEMF) will with mark the day when humanity finally remembers the techniques with which the pyramids, and other ancient megaliths were constructed, this will also mark the day when we remember how to fly!
Remember the following universal truth
"Positive charge attracts positive charge, and expels negative discharge.  Negative discharge repels both negative discharge and positive charge."
        The Universal One
Positive Charge = Paramagnetism = EMF
Negative Discharge = Diamagnetism = BEMF
