Thanks to ALL for your help!!
Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
wizkycho
Hi !
Here is the shematic of what I'm building right now.
at start I'll use 4 pole relay (hope that contacts will all make contact in a same time)
expecting COP 1.4 at first. it doesn't seem much at first but every wat counts.
sorry for the big picture, but if made smaller one can't see numbers.
SV1 i SV7 are contacts for secondary's of mains(220V~) toroid trafo (2*24V~).
(will try in bucking and serial connection). Mains primary is output connected to SV2
This setup allso use discharge from positive and negative plates of capacitors bank or standard operation
(J1 and J2 jumpers will connect to ground , (no coil on SV7))
power input will be adjusted for smallest input (meassured at R3  and R4)
there is no relay contact. I will see if it necessery later.
wiz
wizkycho
Hi all !
this will be test one !
it is a lot simplified schematic than EMF recycler itself, but reasambles key points of design.
pic 1
through S2 TWO currents flow from input source (24V) and stored current from serial connected caps.
Isn't this alone shows that output should be over 100% ? Am I missing some equation here ?
current through S1 is allso added to energy output (at primary).
pic2
through S1 TWO currents flow from input source (24V) and stored current from serial connected caps.
current through S1 is allso added to energy output.
current through S2 is allso added to energy output.
what do you think ?
can someone contact DrSpark to join us on this ?
btw. at the primary I will connect another trafo to step down voltage. I'll try it with relays, should work, but
can someone find appropriate solid state relays opto driven with FETs(low resistance) at the output ?
wizkycho
Perihelion Labs
wizkycho
Quote from: mramos on October 09, 2006, 08:51:21 AM
The relay coil will blow up the junction in the transistor without a diode across the coil.  Also, is power negative?  If not it will not go thru the diodes, and if the jumpers are on, the power will go right to ground?  Is this the whole schematic?  What are you attempting?
24V+ is input power (current goes in, arrow is wrong oriented)
pic1 and pic 2 are steps (reconnection achieved with relay(schematic before))
output at the "primary" output coil of trafo is alternating, scince the currents in "secondary" (input is alternating)
key is to recycle allready used energy, this is a shure thing working. cop 2 min not much but if cascaded...
got all parts and it is 80% assembled.
only need to connect some square gen. for relay output and input power. stay tuned.
let's see what this baby can do.
it will drive a 10Wmin. bulb and with no input at all whatsoever.
wizkycho
wizkycho
Quote from: wizkycho on October 09, 2006, 06:41:04 AM
Hi all !
pic 1
pic2
what do you think ?
wizkycho
Perihelion Labs
Hi all !
What do You all think will this work (pic)?
output is at PRI.
24V+ is input.
observe that current that has allready done work (now stored in capacitors) flows again with "fresh" current
through input coil (SEC on pic).
This alone should guarantee FE ?
if you missed the principle of work
http://drspark.com/idea003.php
please respond
wizkycho
wizkycho
Hi all !
frequency very low (3 - 4Hz)
used 10000uF
input voltage (instead of +24) is 7.5V
oscilgrames are as expected
dirver is four pole relay switch (that is why I wanted to keep low frequency)
osc1(1.gif) between M1 and M2
osc2(2.gif) between M1 and M3 (between M2 and M3 looks the same)
in the next post osc of output.
I will not try to go measure I/O energy ratio cause freq is too low and is hard to flaten input and output measurements
so there would be no mistake with RMS calcs. I want it to be pure and flat DC first.
next tests will use opto transistor switches, higher freqs, and lower capacitance (which is cheaper and easier to get higher voltage rated)
wizkycho
