Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
Charlie_V
Hey guys, man I have been busy with work lately.  I got my own ideas on Tesla coils.
Quote"Tesla Transformers are not magneto-electric devices, they use radiant shock waves, and produce pure voltage without current."
It should read:
"The "Electrical Transformer" is not an electromagnetic device, it is a Magneto-Dielectric device, it produces radiant shock waves, which is current transformed into pure voltage!"
I don't think either is exactly true.  I think its way easier than that.  Heres how Tesla described his wireless power transmission:
"As I perfected my apparatus [Tesla coil], I saw clearly that I can recover,  of that energy which goes in all directions, a large amount, for the simple reason that in the system I designed, once that current got into the earth it had no chance of escaping, because my frequency was low; hence, the electromagnetic radiation was low.  The earth is a vast body.  The potential differences in the earth are small, radiation is very small.  Therefore, if I pass my current into the earth, the energy of the current is stored there as electromagnetic momentum of the vibrations and is not consumed until I put a receiver at a distance, when it will begin to draw the energy and will go to that point and nowhere else."        Nikola Tesla (1916) pg.131  "Nikola Tesla on his works with Alternating Currents and Their Application to Wireless Telegraphy, Telephony, and Transmission of Power"
Now look at a Tesla coil.  The maximum voltage is at the top.  It is a quarter wave resonator!  There is a voltage anti-node at the top (where the ball is) and a voltage node at the base.  Where you have a voltage node you have a current anti-node.  This means the maximum current is at the base.  The base is connected to ground.....  YOU HAVE MAXIMUM CURRENT INTO THE EARTH.  Just like he says.
Now look at this website animation.
http://www.ycars.org/EFRA/Module%20C/tloc.gif
Turn that animation upside down.  The "wire" with the pulse running on it is the earth.  The wire above that is the ionosphere.  The "current" source is your Tesla coil.  There is NO radiant energy surge or hocus pocus in this device.  It is a non-radiating antenna that transfers power using standard (well documented) wave reflections.  A proper Tesla coil should NOT generate sparks - this was just for show, which Tesla admits was the only purpose.
The novel thing is that modern radio engineering calls these "wave reflections" useless and unwanted.  Tesla found a way to use them, and boy did he use them.  This is a much more efficient transmission of energy.
If you followed me this far.  It is worth saying that Tesla discovered that when lightning strikes, it produces these same wave reflections in the earth (this is actually where he got the idea).  A properly tuned magnifying transformer could actually collect these lightning reflections and use it to power devices - day and night.
You can't have voltage without current, but you can have them out of phase.  And that is the trick.  Deriving real power from what is presently called, useless power.
Thats my take on things.  As always I'm open to further learning.
Maximumgravity1
QuoteYou can't have voltage without current
Hmmmm...depends on your definition of voltage and current.  If voltage is pressure, and current is volume of flow, it seems you could, and do, have pressure without flow in static fields.
It seems this is in part what Erfinder is getting at with the magnetic currents being electrostatic fields.  If a chicken produces chickens, voltage produces voltage, pressure produces pressure.  In a transformer, isn't this all that is manipulated?  The voltage is stepped up or down, and any corresponding current is adjusted as a by-product of being "along for the ride"?  The volume of flow is "pinched" or "released" like in a garden hose versus a drain pipe.  In either case water flowing is still water flowing. Chickens produce chickens, pressure produces pressure.
So if a magnetic field induces "voltage" into an ignition coil, is it just not accumulating that which it already is?  As a magneto spins by the coil, due to the frequency (oscillation) of the changing magnetic poles (through the Bloch wall), the coil picks up those reversals in flux polarity - ergo, as erfinder also said, all DC is AC, else it doesn't move (induce) into a coil (it just sits in a static vessel (i.e. permanent magnet)) - which is the same as alternating "poles" or cycles of AC.  It is only when the field enables a coil to do work that the perception of "voltage" is understood.  It is only at that point do we have a viable "quantity" to measure - as we are comparing the distance we force it to move over a given path of a given diameter for a rate of time.    When it just exists in a field, we don't have any way of measuring it's ability to do work - other then in potential difference.  It is all just arbitrary forms of measurement.  Just as we perceive time as the passing of NOW based on our memory, so is the flow of voltage only a measurement when we constrain it to a system we can understand.
On another note, I seem to have had my questions about the condenser answered.  It may help put some things in perspective for others struggling with the condenser.
In detailing high frequency, high potential AC, Tesla had this to say:
"I will now venture to make, in regard to the general manipulation of
induction coils, a few observations bearing upon points which have not
been fully appreciated in earlier experiments with such coils, and are even
now often overlooked.
The secondary of the coil possesses usually such a high self-induction that
the current through the wire is inappreciable, and may be so even when the
terminals are joined by a conductor of small resistance. If capacity is
added to the terminals
, the self-induction is counteracted, and a stronger
current is made to flow through the secondary, though its terminals are
insulated from each other. To one entirely unacquainted with the
properties of alternating currents nothing will look more puzzling. This
feature was illustrated in the experiment performed at the beginning with
the top plates of wire gauze (screen) attached to the terminals and the rubber plate.
When the plates of wire gauze were close together, and a small arc passed
between them, the arc prevented a strong current from passing through the
secondary, because it did away with the capacity on the terminals
; when
the rubber plate was inserted between, the capacity of the condenser
formed counteracted the self-induction of the secondary, a stronger current
passed now, the coil performed more work, and the discharge was by far
more powerful.
The first thing, then, in operating the induction coil is to combine capacity
with the secondary to overcome the self-induction. If the frequencies and
potentials are very high gaseous matter should be carefully kept away
from the charged surfaces. If Leyden jars are used, they should be
immersed in oil, as otherwise considerable dissipation may occur if the
jars are greatly strained. When high frequencies are used, it is of equal
importance to combine a condenser with the primary."
http://ia310937.us.archive.org/0/items/experimentswitha13476gut/13476-h/13476-h.htm
BTW, this is a lengthy, but excellent read.  Some of it drags a bit in discussing the best method of creating high-frequency efficient light bulbs, but there is some good info in here.  Moreover, I started to see a lot of correlation with the above information, and the continual talk of ERFINDER about dielectrics.  It seems there is a lot of confusion with what we consider "resistance" and the ability to get more "flow".  I am still sorting this out, so that is all I will say for now, but others with a better understanding might find it useful.
Esa Maunu
Hi,
Dielectric material has a property under applied radial electric field, that we call as electrostriction.
Electrostriction effect means, that there are quantum vibrations in a dielectric crystal medium. Those vibrations are quantum analoques to mechanical vibration, and are emitting waves that we call as phonons.
Phonons are bosons, posessing integer spin.Because of the integer spin, phonons plays important role in a nature, and are able to interact with all known forces, including gravity.
Also we can create a phonon maser system,with different wave functions and field pattern shapes to collect energy from the environment when a pulsed applied E-field causes stimulated phonon emission in a closed loop system.
We can create this radial E-field with some electronic devices, or with transformers.
Also, if we cut or cancel the magnetic field line with very fast switches, the magnetic energy turns back to radial E-field.
Esa
Grumpy
There is a field more primal than electricity.  This field is known by a few names such as tempic, torsion, and time.  This field is one-dimensional - like pressure.  While this field can exist by itself, electricity can not exist without it, and magnetism not without electricity.
Manipulation of two, can change the third.
        -Frank Edwards
orosado
Hello everyone,
For the sake of keeping everyone on track, this was the last thing that Erfinder asked us to figure out:
Quote from: Erfinder on April 19, 2007, 02:46:01 AM
Good idea adding color to the figure!  Unfortunately your image is missing a color!  There are two secondary circuits!  These two are connected in series!  The intersection formed by these two circuits is extremely special!  Why?  Review it.  Discuss it!
The energy of the future has a name... Magneto-Dielectric Energy!  Where magnetism is static, and electricity is characterized as a high potential high frequency field, which moves inward (implosion) and outward (explosion) simultaneously!  This action simulates the VOID, the zero point which mainstream science is desperately searching for. We will discuss this further after all the patents have been demystified.
It seems that the intersection between the two secondary circuits makes a void, and these secondary circuits compose a sort of capacitor. Exactly how this happens, I do not know.
Regards,
Omar
