Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
0 Members and 23 Guests are viewing this topic.
Trump
midnight_blue[/
    I think your suggestion is good, I think we started out to break the patent down,  but did we really go from the start, or did some of us just take it for granted what some of the wording meant. Working on key points is also a good idea if that will work. It seems that what one person may feel it is a no brainier,  but it may not mean the same to someone else. Again you are right Midnight Blue, we need to be main stream and together on everything. We need to all be on the same track and talk it out. I don't mind Erfinder chewing on me, heck as long as we can work as a group and stay on track it should work. I think what Erfinder is saying is that  all of us are not thinking the same and understanding the same.
Regards,
Charlie_V
Erfinder, I have a question.
This unidirectional radiation you speak of, does this have a name in mainstream or is this something that mainstream does not know about?
Typically, in present understanding, when the primary magnetic field collapses, the secondary will see an increasing magnetic field.  Likewise, when the primary is increasing, the secondary is decreasing.
Could you elaborate a little more on this unidirectional radiation?  It has peeked my interest!
Thanks,
Charlie
brnbrade
Hi Erfinder
You mentioned that a magneto is an electrostatic element. Which is the strength that pushes the individual magnets outside of the magneto?
Does the flow run of the south pole for the north or of the mid for the sides? Magnetism would be the source then of that everything, best saying a vacuum.
Vacuous, it would be a strength that sucks the positive things and it repels the negatives. Or it would be the opposite of that.!!
That vacuous one would be the main grid contained in every infinite of the  universe. That duality + and - in the magneto it would be the Electrostatic and the vacuum the painting screen.
Each individual magnet that flows of that magneto would be the brushes where I drawing my powers.
Example: To alter the south stream and later the north in a rocking frequency would have an alternating current.
And does a direct continue strength  how it would be then?
Thinking like this, could say that to infinite forms of composing a power.
Excuse my questions, but this painting in my mental screen, this wanting to flow of the magnetos.
I wanting incorporate Leonnardo D'vinc that exists in me.
regards
Maximumgravity1
QuoteWell the capacitor stores electrostatic charge as a stress potential in it's dielectric material, and the secondary windings radiate electrostatic charge!
Finally getting to the beginning - the basics.  I still have a hard time understanding how trying to evaluate a completed patent is the beginning, but I will continue to roll with it....
I think some definitions (or concepts of understanding) are needed to form a unified foundation.  I will lay out my thoughts of these definitions, but they are by no means definitive.  Think of these as a starting point to be modified.
Electrostatic Charge - The flow that emanates from an electrostatic field.  This is the "force", the "pressure", the "velocity".
Electrostatic Field - Mainstream defines this as basically, electricity at rest - not moving.  This is kind of an oxymoron, as electricity (flow of energy) is never really at rest.  So I think the idea of force, pressure or velocity flowing (possibly oscillating) in a condensed area is probably sufficient.
Stress Potential - "Stress" - An applied force or system of forces that tends to strain or deform a body.  The "Stress Potential" appears to be the quantitative measurement of electricity to effect physical matter.  This is not through discharge, burn, or release of energy, but the innate ability of Mind to vibrate aetherically.  Maybe too deep, but I am not sure how else to think of this.  Any suggestions on this definition???
High Potential Electrostatic field - If Electrostatic Field is "force, pressure or velocity flowing in a condensed area", isn't this the act of "doing"?  How does this field manifest potential?  Do we assume it is a high force, pressure or velocity?  Do we assume it is a build up of that force, pressure or velocity, waiting for an opportunity to move from its current "condensed area"?
Magnetic Field - ??? Anyone????  The closest I could come is "A detected force that exists around a magnet or electrical field".  In this sense it is clear how the magnetic field is static - it doesn't move - it is bound to an object.  It also does not seem to have varying forms of potential - it just "is".  It can be weaker or stronger, but it doesn't seem to have the ability to provide "more pressure" then what already exists.
So basically, the capacitor (condenser) stores the flow of force in the form of the ability to effect physical matter in its dielectric material, while the secondary coils give off (radiate) the flow of force.
QuoteHmmmm.....interesting....is there anything else?  Yes!  The capacitor and the secondary windings are to be seen as one unit, one system!  The coupling of the secondary windings with capacitor produces a special capacitor!  It should be understood that when the magnetic field of the primary collapses, a unidirectional (direct current in the form of a penetrating radiation) radiation is emitted from the conductor, this radiation is absorbed by the secondary and manifests as a high potential electrostatic field.  What should be noted is that the polarity of the the secondary windings alternate!  This is important as it shows us how a unidirectional (direct current) electrostatic field potential is transformed into an alternating one!!!
In reading through his several hundred times, it appears conductor is probably in reference to the primary coil wire.  So why does the magnetic field's collapse, produce a "penetrating radiation"?  Presumably this "penetrating radiation" is a radiant form of energy that overcomes self-inductance (or is the very cause for self-inductance), and manifests itself as a DC energization of the coil.  But why does it do this?
Now, what can we do with this above information?  How do we apply this info in the patent, and more importantly, what can we learn about the nature of electricity with this info?
Charlie_V
I just don't see how something oscillating is producing a DC radiation - unless he's calling the magnetic field a DC radiation....  I feel so blind :(  I'd like to learn more about it though!
Oh by the way Maximumgravity1, awesome animations.  What your saying makes sense too.  As for a definition for a magnetic field, I got my own but no one likes it.  I call it kinetic energy, a motion field - always present when things are moving.
