Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
samebarbosi
Quote from: allcanadian on April 30, 2007, 07:58:32 PM
... Get some water moving at mach 3 and close the source valve not the outlet, you get massive suction a cold expansion and vaporized water in a near gas like state because it has pulled itself apart. This vapor is not liquid water, nor does it act like liquid water.
Hey, I think I may have solved another question from the statement above.
massive suction=Bemf
cold expansion= cold electricity ---expansion= radiated energy
vaporized water in gas like state= electrostatic radiant energy
"because it has pulled itself apart"= matter to energy transformation?
I find this interesting. I've put in bold what I've never thought before. I was thinking about water hammer as BEMF (but upstream the valve). I think you are right, especially if you have a whole mass of water after the valve (downstream). Never thought about that suction. Not sure if we can call that BEMF, but that's a big suction. Can we compare the magnitude of both Compression vs. Suction?
PS: Erfinder said not long time ago:
Your discussions have not brought any of the hidden truths of this patent to light, this means your thinking has not changed!  It has remained the same from the beginning until now!
I was wandering the same as didn't see any idea I could lay on the paper.
Now I wander again: since I found things I never thought before, how many are still undisclosed yet to discover. I also hope we are not on a false lead; it makes too much sense... it would be such a shame.
Charlie_V
I was thinking about that water hammer stuff and I came to a conclusion. All a water hammer does is convert DC water flow into AC water flow.  If the water flow was already AC, we wouldn't need the water hammer, we would already have it!
I see a lot of posts that talk about radiant energy.  Just remember, by definition, "radiant" energy is a term that defines all electromagnetic radiation.  Light is radiant, radio waves are radiant, gamma rays are radiant - anything that radiates is radiant.  But, this idea of back EMF being a suction.... now that is something!  I never really thought of it in this way.. very cool!
I had a thought, when a fan is blowing, you have an area of high pressure and an area of low pressure.  A jet engine works the same way, the turbines create a large high pressure behind and a low pressure in front - the plane moves toward the area of low pressure.  In the secondary, when the capacitor has a high "pressure" across it, the coils have a "low pressure", low pressure is Back EMF.  This alternates, so there is a point when the capacitor has low pressure, the coils will have high pressure.  When there is low pressure in the coils, the rotor will turn - the suction is doing the work so to speak.  When there is high pressure in the coils, the rotor wouldn't normally move except for whatever momentum was imparted to it during the low pressure cycle.
Normal motors are not made to run in this fashion.  They are made to run when there is high pressure in the coils.  They run on the expansion, not the contraction.  I hope my thinking is getting closer.
By the way, please look at my re-draw of barbosi's circuit diagram.  I think you guys are overlooking how the G coils are also coupled to the F coils.  This isn't a direct coupling like E and F, but they are wound on the same core and their windings are made so that the magnetic field flows from F to G/G to F.
samebarbosi
Quote from: Charlie_V on April 30, 2007, 11:06:09 PM
...I see a lot of posts that talk about radiant energy.  Just remember, by definition, "radiant" energy is a term that defines all electromagnetic radiation.  Light is radiant, radio waves are radiant, gamma rays are radiant - anything that radiates is radiant. ...
Suposition: quote in red. We are not sure about light, gamma reminds me about radioactivity being named after some weird noise detected on radio in proximity of the substance, and I didn't hear anything about heat.
Acceptable (at least for me): quote in bold.
I'm glad you find that suction concept cool too. Well done allcanadian.
Charlie_V
Heat is infrared light.  Actually there are two forms of heat.  Infrared and atoms colliding.  The temperature in rooms and outside is from atoms colliding.  However, the sun heats this with its infrared light.  Gamma rays are the same thing as IR and visible, even UV.  But they are going at a very high oscillating frequency.  Yes, I believe the sun runs cold - remember sun spots are black, not white.
I dunno, you guys don't normally like my explanations, but light, and radiation in general, is not what this motor uses.  Radiation is the expansion force, our motor is running off suction.
Hahaha, I love this explanation, it makes a lot of sense to me.  Unfortunately, someone will come on tomorrow and show me I'm wrong about it.... oh well I'll enjoy while it lasts lol!
allcanadian
I get my explanations from so many sources it's not even funny, the suction analogy is pure Victor Schauberger. I have been looking for a good analogy to describe the  electrical equivalent for a while, I can't believe it just popped into my head today. As well it is well known that most documented OU devices run cold, how can machines doing work have all there components run cold?
Compression/contraction and pressure produce heat, evaporation/expansion and suction produce cold. So I equate what is happening in the secondaries during a Bemf  spike as electricity being torn apart under a massive suction, transformed into radiating electrostatic potential.
The radiant energy in question here is Teslas radiant energy, it is not EM radiation, Tesla was very specific in the fact that his radiant waves could easily penetrate copper and iron barriers which EM cannot. I finally got the answer on radiant energy last week. It is created by impulse current and travels as a longitudinal oscillating wave. Oscillating is not alternating, an oscillating wave is a compression/expansion like a sound wave in air, where alternating waves are like ocean waves.
What is interesting is that these waves travel 1.5 times the speed of light, so any calculations or meters are basically useless, everything we know is tied to the speed of light which means we don't know much .
I hope erfinder pipes in soon so I can figure out if Im blowing hot air or not. I think Im getting warm, the answers I found finally make more sense.
