Gravity Free Energy Generator
Started by Newton II, March 04, 2013, 04:49:38 AM
Newton II
This device looks very interesting to me.   A part of  energy generated at the center of a huge rotating lever arm is transferred to the outer edge of the arm by means of a propelling system to keep the arm rotating.  The arm produces tremendous torque at the center producing considerable energy.   A very simple method of making use of mechanical advantage!   Gain in torque may be lost in time as per lever rules but still mechanical, electrical and aerodynamics everything combined in one system may have the chance of working????
http://www.youtube.com/watch?v=U7AN2IR8p9w
Can anybody prove or disprove it?
Tok
Well, the propeller for sure does not have enough torque to keep it spinning. and if the propeller is in the constant speed, then by aerodynamics the propeller slows down the arm when the arm comes from up position to the down position. It simply makes "Air friction". Cool concept but I thing it is not working one.
Newton II
What happens if propeller is replaced by an electromagnet which is repelled by an external permanent magnet?   I mean generator coil at the center and motor coil on the edge?  Will it not have additional mechanical advantage?
Newton II
But how he is doing that trick?  Aerosensitive?
Tok
As you can see in the video, the "Machine" actually slows down. The video is stopped in the very moment and continued when the rotation is established again. Simple as that. No gain.
