Adam' syle pulse magnetic motor genorator
Started by mag_force, March 04, 2013, 08:50:00 PM
mag_force
hello everyone..
I am new to this site so i am sorry in advance if any of my questions are redundent...
i am trying to replicate Robert Adam's pulse generator and so far i am doing well in this task, but some things have seemed to elude me one of large consern for me at the pressent, is in the construction of drive and pick-up coils that will be used in my motor
I am using #19 awg magnet wire, and am not restricked with materials to use however currently i will be using turned iron for my core.
the goal of this motor will be to produce at least 14v of excess power i am trying to find out how large of a core and magnet/s are needed to produce such a voltage when a neodium magnet is used.. as neodium fields are much stronger than typicly used magnets, im hoping for less mass more result..(so to say)
mag_force
plz any comments are more than welcome i have been tinkering with this on and off for over 10 years now even before 09 and the physics in my mind it works rather well >:( however prototypes have just started showing any real output of any kind and i believe it is maillly do to my maget.. coil core relationship. i have alway been good with electric and saw this potental will still in high school howevr when asking my questions it was impossible........ so for as a teacher was consernd to entertain that they might not know it all, was out of the question. so here i am ten years later talking to fellow impossabilatists...lol i need to be enlighted i will have drawings avalable soon as a scaner is eluding me for the moment.. look forward to hearing from you all and hope to solve for E soon, lol
mag_force
here is a sorry excuse of a diagram i whipped up on paint so you men and women out there can get an idea of what im going for....
i am using a hall effect sensor to "fire" electromagnet coils x3 120 deg. apart from each  other i am then placing x2 coils 120 deg. apart but off set 15deg. from first "drive coil".....
permanate magnets are as described 1/8" x 1/4" n25 neo. magnets placed at 30 deg intervals around a 9" poly disk mounted to  1/2"x9"alluminum shaft
drive coils are rated at 12v .25 amp 3w
im looking for pick-up coil to produce at least 3volts 2amp for this app. as i can then take it and collect the same collapse plus increase voltage and run it to storage battery...
come to think of it has anyone ever tryed to place large forward diode on to the pos. of recharging battery to try and spop the "ghosting" effect?
mag_force
ok by hooking up my wheel to the frame and placing my drive coils around the wheel in the 120 deg. pattern as shown below with an air gap of approx. 5mm off the edge of the drive wheel.
my question is... with an osciliscope which i just happen to have what am i exactly looking for to see what kind of CEMF i am producing in contrast to the three drive coils that will be using 0.75 amps at 12 v.
what kinda of varriables do i really need to consern my self with at this point i see people like imhotep have used a computer fan and so on which i fould had many simularity's to some of my original motor plans, and have been very instrumential with helping me approach this area with a new found hope that maybe enough of us haven't been buffuloed into the main line thinking that the   "world is flat" thank god we didnt try this durring the witch hunts... THANX Community i have been following different threads for 5months solid now and from what i can see well are all right on the cusp of a new line of thinking for the world of energy how ever lets not get into "global fraud"
here is a top view of the last pic.. all poles are N, and drive coil is set to repel on energize again i appoligize for the paint editing but i believe people should be able to understand it well enough, as i still cant get scanner to work properly
ALVARO_CS
Hello
I found very helpful info at:  http://www.totallyamped.net/adams/index.html
Also much info in the Patrick J Kelly : PJK pdf book (free download) chapter 2
cheers
