Adam' syle pulse magnetic motor genorator
Started by mag_force, March 04, 2013, 08:50:00 PM
mag_force
Thank you for the extra reading  alvaro..... very help full and put enough questions to rest to be confident on over unity prototype
however i do have one more simple question to ask our folks out there with the given ~5mm air gap given is thier any way to calculate the repelling forces between two magnets one being neo. , and electro. the other? im trying to make a double check of my math for a ramped up version potentully 10kw
i figured about 5%, loss over 5mm. but as i do not have a proper shaft, modified to apply a torque wrench to it i have no way of accuratly meassuring repell force it this time.
im hopeing sommeone out there has possiblly measered this.. as it would be kinda helpful to me thanks again for the reply hope to hear more from anyone interested
also is there anyone doing work with trying to use the CEMF in a reversed form of producing hydrogen? "cold fusion" i guess is what im thinking of maybe
mag_force
ok so i have determined adam's use of two different coil matterials to be just one of many more interesting things this man sought to use as bennificial to his motor design but i am having a little trouble finding 301 stainless steel that is a pertty important part of this design, i looked up simular steel mixes and found that possiblly i could use "303" but as i do not have any expertize in this matter i would like to know if any chemists are out there that might help.
I am believing the stainless is using its nickle as a conductor to the carbon (iron) but as nickle is not magnetic its self, it will not have the attracting force of the gray iron core of the pick-up coil, i am also in conflict with what i have been reading, adam's used a laminated core to limit the amount of eddie current through his pick-up coil.... But if using the bedini cirrcuit to collect back emf  or (CEMF) off of the coil whould in it be benaficiall to have a large eddie current as this would give you a larger collapse in the coils field? i would love to hear a thought or two on this subject.
thanx much
