Simple Lenzless Generator
Started by Neo-X, March 06, 2013, 04:54:24 AM
Neo-X
Hellow 2 all.. I was currious why nobody build a faraday disc generator where the disc is made of spiral conductor rather than solid disc? I think it will  work the same as solid disc but with higher voltage. It also greatly reduces the eddy current and doesnt need many brushes on its rim (one brush i think is enough) which reduces greatly the friction.
Doug1
You need to read Teslas notes on the device more closely. Search a little bit and find the photo of the giant unit used back in the past used in the to develop the A bomb materials.Now it's a yard orniment someplace. Very little details about it's construction can be found, well none to be exact. One or two studies have been done on small table top models. Even they could not resist changing the design before studying the original.
Bruce_TPU
Quote from: Neo-X on March 06, 2013, 04:54:24 AM
Hi Neo-X,
I believe that you are on the right track.  I started a thread some time ago on the subject.  The only thing different that I would add to what I have written, is that I would use LITZ wire for the pancake.
http://www.overunity.com/8934/bruces-discovery-teslas-missing-link-for-his-unipolar-generator/msg233712/#msg233712
Cheers,
Bruce
DreamThinkBuild
Hi Bruce,
There was another patent that recently popped up.
US8288910 - Multi-winding homopolar electric machine
http://www.google.com/patents/US8288910
Quote...where N corresponds to the number of turns of the wire about the cylinder 24. By increasing the number of turns, the voltage and speed can be made to essentially any value. For example, if the present invention is utilized as a generator that must supply 5V to a load, with 1000 turns of wire the speed required to develop 5V would be 1000 times less than a single-turn prior art homopolar machine. If the operating parameters of the prior art homopolar machine required 1000 RPMs to produce 5V, the present invention would require 1 RPM for the same voltage output. The corresponding counter torque would also be additive, causing the rotation to require higher torque at 1 RPM...
Neo-X
@bruce_tpu I like your thread.. Full of usefull ideas and information. On the picture i like the your first idea. I think that was the best way to draw the current out of the disc. With that setup friction will become greatly reduce and the brush ware will be lessen.
