Reduced Cross Section Pseudo Solid Transfer, proof of overunity from magnets
Started by gammarayburst, March 23, 2013, 11:57:23 AM
Gwandau
gammarayburst,
This is indeed an interesting area of research.
Tampering with the flux patterns opens up a complex domain of electromagnetic interference geometry, and may be the correct approach in attaining the needed breach in the magnetic field balance.
It makes me think of the technique used by permanent magnetic lifters. Some has a capacity to lift up to nine thousand kilos of metal weight and the enormous attraction just as easily released by a simple twist of a handle, neutralizing the attractive force by effectively short circuiting the huge neodynium magnet inside.
I did some working with such lifters, and was amazed that the incredible strength of the magnet so easily was canceled out by turning the handle with almost no force.
Short circuiting flux patterns may be essentiqal in braking the magnetic equilibrium. Once the resultant field balance is broken, the road to magnetic motors are open.
Gwandau
gammarayburst
Gwandau,
I agree. What makes this work is using the Pseudo Solid movement of the magnets from one element to another because the air gap problem is by-passed and when a high aspect ratio magnet is used the magnet end is so small that the work needed to seperate the two is a small fraction of the work done when the two elements are pulled to each other or repelled from each other. I have not had a negative test yet with this procedure. I see the magnet motor or generator problem as solved at this point.
Regards, Butch LaFonte
