I Cube Transformer
Started by icorex11, March 26, 2013, 09:47:25 AM
icorex11
The  I Cube  is a multi core transformer it can be arranged in many many configurations , includeing high voltage  high amprage high frequency aswell as low voltage self running basically it can be made for any application  I build thease units from recycled parts ...   i own an E WASTE recycleing company !  im currently selling cores . i have a number of prototypes built
cores can be purchised from me via  pvt msg
the core material is feroite  i take advantage of a shape shifting core .. and use it to my gain !
the shape shifting core transforms from square to round ...  in doing so common sence comes into play ...
the I CUBE core is comprised of 4 indivual cores ...  connected as one in a cube configuration transforming from square to round
its quite a neat design
cores are forsale at $120 cdn each basically im selling a single core at 30$ this pays for the time involved to CLEAN UP THE CORES for use .. and nothing more ... compleated and wound units are forsale aswell  but no price has been set yet !
more information to follow soon !
ARX11
icorex11
the ICUBE  is made from 4 flyback cores  identical  they arranged to make a square shape in the center of the core  this is the supply side  makeing a magnetic feild in the feroite  but being the core is square  and transforms to round  i expect i will acheive a larger magnetic feild in the feroite useing a square core ...
in my experience with square magnets  common sence has told me there more magnetic feilds in a square than in a round magnet ... being that the square or cube ..  has more sides than  a round one ...  so a cube infact pushes and pulls magnetics from 6 locations  with this in mind ..
i decided to build a square core of feroite ...  now the round part ....  the rounds are secondaries  they exert magnetics in a omni dirrection from the core   so if square is powered  produceing  6  locations  of magnetics  and is forced to round  and then extracted ... i beleave this to be an improvement to convencal means .. of transformer configurations
here is the ICUBE core i have come up with
icorex11
this picticular ICUBE core  was designed for high frequency med voltage high current ! it was designed origonally for a  ULTRA CAP charger so it has been wound and the driveing curcit built to suit those needs ... this core showen is an ICUBE DUO as per the winding and  driver ...
i expect it can be made to be verry powerfull or  verry mild depending on application
im not makeing a claim of overunity ....
im displaying some of my newer technoligies this core can be used in many ways including some of my older technoligies such as self running low voltage ..  it can be made as a joule theif  or any number of diffrent arrangements of drivers
i deem this transformer  VERY USEFUL!
ARX11
icorex11
in this wireing configuration  you will notice that the  primary pluse coil is center tapped it is wound all 1 dirrection  and 2 npn transistors are used in this unit  1 to eather end of the pulse coil center tap is +  on top of this coil goes the trigger coil or feedback coil or sence coil ... or call it as you will ...   it is also 1 wire wound same dirrection center tapped  and agin  hooked up to the transistors..
and thats about it  the secondaries get wound on the rounds and they are in this current configuration 24 ga magnet wire and 66 turns per core round ..
ARX11
aaron5120
icorex11,
You have all the resources needed to make a delayed Lenz transformer.
Instead of winding the secondaries in the center core, put them in the outer arms of the cube. Use thinner gauge magnet wire for the secondaries.
For details and hints, please refer to the following link:
http://jnaudin.free.fr/dlenz/heinseffecten.htm
The load will not reflect back to the primary due to the Heins Effect. Use a Sound Amplifier and Signal Generator to drive the monster coil you will be winding.
aaron5120
