The main question is: Why Gravity takes effect on Matter?
Started by derekwillstar, April 08, 2013, 09:10:46 PM
derekwillstar
Quote from: jbignes5 on April 21, 2013, 04:01:16 PM
Well magnetism is the result of the electric field. In nature this is how everything works. The origin is the potential values of bodies in space. This is because we live in a huge field called our solar system. Yes the end point is the sun and reflects back all the potential of our solar system.
Gravity on the other hand is a central point to that potential field. In our case the sun at solar system scale but much closer is our planet. Because space is displaced it creates a vacuum of the space medium, this medium likes to stay balanced and uniform but matter displaces this space and a potential is formed inside of that matter. In the true center of matter is the vacuum and not in space. Space is only the field that our matter floats in and displaces. Like our planet all objects displace space and all objects then are effected by each other when brought into near field.
This vacuum creates or makes the space field want to flow towards it and will do so in between matter. What is attracted in that flow is a very even flow of charges that get dragged along with the flow of space towards the center spot.
As for the video I saw nothing out of the ordinary in it. here was just as much pixelation around your skin of your hand as I saw around the contrasting colors you put together. This is due to compression errors in the video processing of YouTube.
It doesn't seem to be anything to note in the video, in my opinion.
so to be clear gravity isn't because of anything but the electric field of our solar system and it's reaction to being displaced by matter.
The video is not mine, but David Lambright
http://www.youtube.com/user/potatoheadist?feature=watch
worth more later time (240p) the distortion occurs at the end of the magnet, and this is not a youtube effect.
Otherwise you can see this :
http://www.youtube.com/watch?v=uRgcC_mK97k
From the description of the video :
i am using a 1 1/2" aluminum tube filled with iron oxide [charged like a PMH] the rock is sedimentary with lots of shells in it. this video is more like what i see. the distortion of image under the stone i like a liquid. when i move the stone around in the field, i sometimes see eddys [whirlpools]from the corners. this is exciting. this energy is like a mirage. and a mirage is a reflective surface. add a circular eddy and you get a lens. it has been hard enough to get the image of this field, getting images of the eddys i am sure will prove to be difficult, but i will get images of this phenomena. to anyone not familiar with my devices, i made a PMH ,[Leedskalnin], using iron oxide inside the aluminum tube.i energized with a 9.6 volt DC battery six months previous and removed the coil.
is dramatically important to understand that magnetism can distort the light, and what we see!
since spoken of electricity, public writings of Edward Leedskalnin electricity:
Before my research work I knew nothing about electricity. The only thing I knew was that nobody knows what electricity is. So I thought I am going to find out why they do not know. I thought that if electricity could be made and managed for over a hundred years, then the makers do not know what it is, there is something wrong about it. I found out that the researchers were misled by wrong instruction books, and by one-sided instruments. Voltmeters and ampere meters are one-sided. They only show what is called by instruction books, positive electricity, but never show negative electricity. Now you can see that one-half of the electricity escaped their notice. If the researchers had used the same kind of equipment I use to demonstrate what magnetic current is, they would have found out a long time ago what electricity is. The positive electricity is composed of streams of north pole individual magnets, and negative electricity is composed of streams of south pole individual magnets. They are running one stream of magnets against the other stream in whirling right hand twist, and with high speed.
    Protons and electrons—Are you sure they are not the north and south pole individual magnets. If we have anything we have to show that we have it. Show the base where it came from, and show how the thing functions.  We can find concentrated north and south pole individual magnets in the earth, in a metal. With the metal we can demonstrate that the free north and south pole individual magnets are circulating in the earth. In the North Hemisphere the south pole individual magnets are going up, and the north pole individual magnets are coming down. Those free circulating north and south individual magnets are the building material for the magnet metal we find in the earth. This should show that the north and south pole individual magnets are the real atom builders, and not the protons and electrons.(...continue)
to deepen, please refer to the original document :
http://www.leedskalnin.com/Leedskalnins-Writings-ADVERTISEMENT.html
derekwillstar
greetings
I had problems with the site fortunadrago.it, was off from 23/04 to 25/04 but now it seems to work well ...  :o
in summary ...
Edward Leedskalnin makes some observations on electricity, tools (all) measure only the positive direction of electricity, he realizes that "In the North Hemisphere the south pole individual magnets are going up, and the north pole individual magnets are coming down" and he's not discussing the normal earth's magnetic field, but Gravity and (in my opinion) is confirming that that is the Law of Rhythm Pier Luigi Ighina:
http://www.fortunadrago.it/?page_id=279 (translation on top right)
"In the north Hemisfere" place where there is Coral Castle (Homestead - Florida - USA)
"South pole individual magnets are going up," this is the flow of monopolies as "individual magnets" negative, cold, yin, blue, polarity of the south, coming from the center of the earth and the sun ascends. (left handed)
"And the north pole individual magnets are coming down," this is the flow of monopolies positive, warm, yang, yellow, polarity of the north, which comes from the sun, through any kind of matter existing in creation, giving to it (in its fall toward the center of the Earth) the acceleration of gravity. (right handed)
http://www.youtube.com/watch?v=3O6V6EiG2F8
This flow reaching the center of the earth on all sides, collide and reversed by changing polarity (north to south), the direction of rotation (from right-handed to left pattern), color (from yellow to blue), from hot to cold and not more downward, but upward to the sun.
the two flows mono-magnetic against whirling  give origin to a powerful balance between them, whose only result is precisely the acceleration of gravity!
A difficult balance to break, it takes a lot of energy to break it, as in the case of the machine of the monopolies :
http://www.fortunadrago.it/?page_id=377 (translation on top right)
This machine whirling through the coils (which could only withstand 12V) but powered by 132V (only from batteries)!
Break the normal balance between the flow of monopolies, capturing them and making them available.
It is a generator whatever, but it is able to unbalance the vital energy of those who are in the immediate vicinity!
(such as skin rashes, stomach cramps, sudden anger)
Roi
 [font=]The main question is: Why Gravity takes effect on Matter?[/font]
[font=]I guess that the best main question is: How Gravity works?[/font]
Maybe some answers can be found here:
www.quantumgravity.us
This guy is against the physics mainstream!
Publicly, he admitted the existence of possibility to get free energy!
derekwillstar
Quote from: Roi on April 29, 2013, 02:53:22 PM
Gravity is something tangible, existing!
it is linked to the matter and the survival of creation itself.
we can not deal with the problem only from the scientific side, there is need to expand the discourse precisely because the gravity imposes it!
jbignes5
Quote from: derekwillstar on April 22, 2013, 05:00:07 AM
I in fact know who was the originator of the video. But as you can see from any video with a bright pattern like the yellow mat he used under the device that it causes pixilation errors in the video due to the digital transform process. It is a sort of matrixing even that happen to edges of dark with bright patterned backgrounds. matrixing is a product of those patterns when converting one resolution to the next. In fact most video cards have a driver based algorythem that deals with this problem on a hardware level. Antialiasing is this algorythem.
It is a well know effect and There is a fix for it but only in the video hardware. Since YouTube is come of age it still has not dealt with this issue and most video cameras do not deal with it as well. If this would happen with an analogue video camera I would be inclined to look into it but it doesn't. matrixing is a digital effect and not an analogue one.
As for gravity what does this have to do with it? A magnetic field has nothing to do with gravity. It is the effect of the electric field on space and matter. First you need the potential field and then expose matter to the field and then you get a current, which we call magnetic current. Without the electric field there is no current and hence no magnetic field.
If you want to understand gravity one needs to understand the electric field and how it interacts with matter to create a pull towards the center of the mass. If you look at the periodic table you will see that all matter has a standing potential or commonly called electro negativity. lets look at copper for instance: http://en.wikipedia.org/wiki/Copper
If we understand that masses the size of our planet actually have a distance associated with it and an additive potential as well. The surface of the planet would have a value associated with it and is concentrated inside of the planet into the core. Since there is heavy iron at the core this electric potential becomes active and changes a portion of the electrical potential of the whole of the planet into a magnetic, heat, and gravity components.
None of this would be possible without the electric field and the potential of the matter in that electric field. Each body in space is additive to the whole scale of the body in space. This is not limited to solid bodies, it also includes the solar system and galaxy as well. This is how gravity works plain and simple.
