The main question is: Why Gravity takes effect on Matter?
Started by derekwillstar, April 08, 2013, 09:10:46 PM
gravityblock
Also, earth does have a hollow center, where there is a glowing ball of magnetism (remnants of it's former self of being a sun).  On the other-hand, the moon is mostly solid, with a very small hollow center of glowing magnetism.  The argument made by milehigh against a hollow earth isn't valid because a glowing ball of magnestim at the hollow center of the earth has been overlooked by him and by his teachers.
Gravock
jbignes5
Quote from: derekwillstar on May 02, 2013, 05:34:28 AM
http://peswiki.com/images/c/ce/Ed_Leedskalnin-pushpull.gif
all of nature is monopolar magnetic matter (know the magnetic toy "geomag"? behold, the matter is made that way, and accurately...
Edward Leedskalnin indicates an atom of matter as its model of PMH :
http://www.fortunadrago.it/wp-content/uploads/2011/09/PMH_MVAL_op_488x600.jpg
electricity is a magnetic current
http://www.youtube.com/watch?feature=player_embedded&v=SO3dXCsyBC4
Electricity is not a magnetic current. You can not have a magnetic current without the electric field setup by the potential of the bodies in space. If there were a way to get magnetism without using the electric field we would have Overunity in leaps and bounds.
Each body in space weather it be a planet or much smaller scaled atom has a potential associated with it. This potential field sets up the electric field and a magnetic force is then able to span the electric field. Without the potential of individual atoms in space there is zero chance of the electric field forming in between those potential and zero chance that the magnetic field can form.
This is where the backwards thinking of our predecessors got us in trouble.
Case in point: When we try to create a magnetic field it is impossible to do this without either matter aligned by the electric field or more directly the electric field itself via potential differences in matter like a battery.
But we can create a difference in potential by using matter itself. The crystal battery is a very good example of this. There are plenty of examples of the crystal battery on this forum and through these experiments and examples we can generate light from the potential difference of two different materials with a crystalline barrier in between. This is due to the standing potential of each plate and connected via the crystalline material and a current flows between the two plates when a load is placed in between the two materials. This power will last forever as long as you do not deplete the standing potentials of the materials and this is evident by all of the examples of crystalline batteries on this and many other forums.
You are simply wrong in your assumption that the magnetic precedes the electric. This is our error in science and your beliefs. You have been misled by the academics because they will never admit they are wrong.
If you want to learn the truth then I would highly recommend "The Electric Universe" as a starting point. Gravity is merely a gentile flow of charges that are attracted to a central point of a body in space. The interactions that arise among the bodies of space and the subsequent magnetic flows are results of the potential differences of the individual bodies, weather they are planet sized or atom sized.
We must start understanding these processes and the first step in this is to observe the processes. This is what the electric universe project is doing and they are now in the position to rewrite our wrong theories and naive assessments of our past.
With only using the standing potential of 2 bodies separated by a one way material we have and will always be able to draw unlimited amounts of energy from the whole electric field of the immediate larger body in space. This has been proven through experimental observation. lasersaber has a crystal battery that has been running for over a year now powering both a motor and an led and viewable online via a webcam.  Many many others have had this experience, including me. It is irrefutable.
gravityblock
Quote from: jbignes5 on May 02, 2013, 02:39:18 PM
Jbignes,
Magnetism is nothing more than a space devoid of all matter.  In the vacuum of space, a moving electric field isn't necessary in order to induce a magnetic field.
Gravock
jbignes5
Quote from: gravityblock on May 02, 2013, 02:22:29 PM
Gravock
Until you can show this premise then it will never float. The moon is very hollow and it has been proven by objects hitting the moon then the moon rings for hours afterwards. I will agree with that.
The earth is not hollow and neither is our sun. They are very  liquid in the center and in the very center have a crystal that are made because of the very high temperatures and extreme pressure. In both cases of our planet and sun these crystals are made out of iron. This does two things. 1 it is an interface of the potential and the real charges being sucked into our cores then 2 creates a magnetic field via the iron crystal in that core. Both the sun and earth have these features and is based wholly out of the total potential of our solar system. The sun is actually an anode of the galactic potential and this is what sets up the electric field of our solar system. The planets are actually sinks of the potential field and create heat and magnetism out of this potential field along with potential field of each body in that solar field. It is after all a fractal repeating from the universe all the way down to the individual atoms. Each part of the fractal will show the whole fractal no matter where you are in that fractal almost like in a hologram.
jbignes5
Quote from: gravityblock on May 02, 2013, 02:51:33 PM
Jbignes,
Magnetism is nothing more than space devoid of all matter.
Gravock
until you can provide proof of this statement it is only a theory.
The electric universe shows proof and until you negate that proof then the Axiom of theories can not disprove facts is where I'll stay.
