New research on extending and improving solar cell output.
Started by The Architect, April 10, 2013, 04:17:35 PM
The Architect
I am working on some new research that I will post video links to the info and process as well as verification so hopefully it will propagate out quickly, that is something that can be done to improve the lifespan and power output of conventional silicon solar cells, possibly so much as to boost the power output to over 300% of the current efficiency, while making them a longer lasting solution to the number of say 200 or more years of 100-90% of their original production potential, instead of them dropping to 90% in 20 years as they do now. I will do my best to in the video to explain my theory of why this is working the way it does, so that others can more fully build on my research and push this concept till it makes solar cells a fully viable solution with them giving back more power than it takes to make them, and leaves excess power for running other things.
another aspect is a potential to store photonic energy to be released during drops in light (*clouds or night time) that could possibly allow solar cells to put out up to 40% of their daily output up to 8 hours after the sun has set! (imagine how much less need there would be for the battery storage backup systems making a fraction of the batteries and such being needed to maintain full power 24 hours a day, if you got power from solar cells up to 20 hours a day or even 18 hours a day :)
staytuned here or http://igg.me/at/teslabill/x/1065580 on the fundraiser page I am running to build a research facility for the public, (ie anyone can walk in off the street and use tools and resources to work on their research, and we will be focused on alternative energy, like having a Tesla technology dedicated shielded room outfitted with some essentials like a good sized and mid sized Tesla coil, and the same opensourced benign mentality that Tesla himself was known to exhibit.
and here at:
my youtube channel, www.youtube.com/user/morphtrust as I will be making my videos and instructions on how to use the findings I have already reached available for all to see there.
Understand my boosting power to the cells is NOT achieved by applying MORE sunlight, but rather by applying LESS of the sunlight to the cells, and I know this sounds crazy but once you understand what is going on at an atomic level, I am certain you will not only see why it works but should possibly begin seeing ways to improve this concept :)
The Architect
by the way I will be looking to get help with both grabbing the videos and reloading them else where, as well as translating them so people anywhere will be able to understand and use the info to modify their current and future solar cells they plan to set up.
remember so far, a pair of shears or scissors, and some stuff from a plastic supply is all that is needed for the first stage, the second will require some resources that would normally be used for raves and such, but should still be fairly easy to obtain, and to use them you will need a spin caster and some clear paint and thinner to apply it as thickness is going to be important, to thick and it will interfere with energy production, to thin and it will not offer optimum support, so I would be hitting up some instructions for doing that, one good place I found was this gentleman's videos, I will also post how I made standard harddrives into a spincaster and small centrifuges with out much other than a computer powersupply. (if you are magnet chaser like I am then you should have plenty of these sitting around that you extracted the magnets out of XD)
I will try to get on to other projects too, but the art work for the Tesla bill is going to eat up most of my spare time so, only one project at a time for now :)
I will release PDF and DWG or DXF files for all the parts for the spinning tools made with hard drives, for all the brands I find that work for this, and include some lists of the hard drives I took apart and got good results, like some spin 15 seconds then stop for about 4 to 5 seconds then spin 15 seconds and stop 4 to 5 seconds repeating this process indefinitely, others will spin longer and then stop, some times up to 3 minutes, and need to be unplugged to get them to spin again, so a switch for this I am going to see if I can rig up, and setup a timer with long pulses to get it to run on it's own, using a 555 timer :)
more later.
gotoluc
Looking forward to what you have to share as I'm presently building a solar powered houseboat.
Thanks for sharing
Luc
Ronwg
