Tesla's "COIL FOR ELECTRO-MAGNETS".
Started by Farmhand, April 21, 2013, 09:00:24 AM
synchro1
I just re-performed "Tesla Coil's" bifilar nail experiment and got his 2x the strength results. Two problems: one; Lash winding and Two; Failure to energize the SBC are reasons I suspect that caused the other experimental failures.
Precise and tight wire wraps are essential in this experiment. This is how Tesla earned a patent for an electromagnet coil. He had to demonstrate a practical advantage to his U.S. Patent examiners. Also, the SBC won't work cold! It has to be "Energized". I charged both the SBC and the single wire coil with 12 volts, and tested their field strengths with 6 volts. After energizing the SBC, it lifted two paper clips from the table surface, where the single wire coil would only attach one to the face.
"Lorentz" explained how this additional magnetic strength results from electron interaction in the SBC.
Magluvin
Quote from: synchro1 on May 18, 2013, 04:48:13 PM
I just re-performed "Tesla Coil's" bifilar nail experiment and got his 2x the strength results. Two problems, one; Lash winding and failure to energize the SBC are reasons I suspect that caused the other experimental failures.
What does this mean specifically?  "Two problems, one; Lash winding and failure to energize the SBC are reasons I suspect that caused the other experimental failures."
Let me know what Im doing wrong so I can correct it. I have them already wound, ready for action. ;D
Mags
Magluvin
Also, the SBC won't work cold! It has to be charged.
"Has to be charged"   Ok, does that mean connecting the battery to the coil ends but where the coil is connected in series is where we should have our make and break switching, all so that each winding, one is fully positive and the other is fully negative because they are connected to the battery already?   ;)
Mags
synchro1
Quote from: Magluvin on May 18, 2013, 05:01:36 PM
Mags
Are the nail cores magnetic iron? Are the wraps 26 gauge, tight against the iron core in one layer, and precision wound with no overlay? Did you "Energize" the SBC coil with High Voltage shock?
Magluvin
Quote from: synchro1 on May 18, 2013, 05:12:03 PM
"Did you "Energize" the SBC coil with High Voltage shock?"  LOL, no I did not. Can you show some link or reference to this subject or describe it a bit more?
Mags
