Tesla's "COIL FOR ELECTRO-MAGNETS".
Started by Farmhand, April 21, 2013, 09:00:24 AM
picowatt
These guy's only need #8 wire for their 48" lifter, and #6 wire for up to their 57" model.  They use 230VDC for the supply.
Those wire sizes seem consistent with those in that 1914 photo.
http://www.walkermagnet.com/scrap-magnets-scrapmaster.htm
PW
synchro1
That was called the "Westinghouse Magnet". The only thing those wires did was charge the 6 volt battery. A very thick wire bifilar pancake "Impulse charging Coil" lay flat up against the iron ferrite magnet disk. A large thermos size capacitor supplied the pulse.
picowatt
Quote from: synchro1 on May 26, 2013, 08:31:03 PM
Synchro1,
Do you have any evidence or references that verify that?
The 1914 image looks consistent with every other DC lifter.  A DC lifter of that era would likely use a cap to suppress arcing across the power on/off switch.  If rectified AC was used, it was likely smoothed with a cap to reduce eddie current heating.  More likely a DC gen was used, as rectifying AC back then, at that level, usually meant using mercury arc rectifiers.  Even a commutated DC gen output would benefit from some smoothing using a cap, again to reduce eddie current heating.
Just curious as to whether you have supporting material for your claim or if this is just speculation on your part.
PW
Magluvin
Here is a cutaway view of the old scrap magnet below. And the page link here.
http://en.wikipedia.org/wiki/File:Lifting_electromagnet_cross_section.png
It says flat conductors and it looks like 4 pancakes together?
Then there is this from a link you guys provided. Its the repair page with some pics that show flat conductors.
http://www.walkermagnet.com/service-repair-scrap-magnet-repair.htm
Mags
picowatt
Quote from: Magluvin on May 26, 2013, 09:35:34 PM
Mags
Hey Mags,
Is it not logical to expect that some lifter designs may use multiple coils as a way to increase ampere turns for more lifting power or to allow for a more physically compact unit?  Any increase in DC resistance can be compensated for via application of a higher DC voltage to maintain a given DC current.
Heating of the windings is usually a limiting factor with these lifters, and you will note that the mfg page cited specifies a 75% or so duty cycle for most of their lifters.
I just don't see anything in that 1914 image that is not consistent with a standard DC lifter.
PW
