Tesla's "COIL FOR ELECTRO-MAGNETS".
Started by Farmhand, April 21, 2013, 09:00:24 AM
Farmhand
Regarding the increased capacity of the coil for storing energy, would the bifilar coil release all of that
extra energy it takes in and stores if it was used as a series inductor ? As in a charging inductor for a
resonant charging circuit for a Tesla coil pre-primary ect.. It could be useful for that purpose maybe.
The one I made above just happens to be the same frequency as some of my Tesla coils.
As far as for any application, the lowering of the resonant frequency could be very useful.
I remember Slider from EF found some bifilar type/wound coils in an old TV or something, he
talked about it in the Romero Muller thread at EF.
It would seem the self capacitance was increased by almost a factor of 3 in the coils I wound above.
synchro1
This underscores my "Magnetic Resonance Theory".
Quote from Farmhand:
"The one I made above just happens to be the same frequency as some of my Tesla coils".
Farmhand
My function generator is a bodgy unit, the frequency drifts badly for some reason. I've built oscillators and pulsing circuits
that hold a nice steady frequency, I don't get why the bought FG frequency drifts, No one should buy one like the one I
have it isn't very good in that way.
That's why I can't get the frequency to stay spot on where it should be so I apologize for that.  :-[
I see there are cheap digital ones on ebay but the output of those is less.
Cheers
synchro1
jbignes5
 I am so very glad you have started this Farmhand. I applaud your exploration of the coil that will change our lives.
The problem with bifilar coils is they are designed for pulsed operation. They do not respond well to analogue stimulation. At least not equalled response.  The impulse method is where Bifilar coils excel. With a suitable capacitor one can make the bifilar output way more magnetic response then any other coil in existence if a core is included. In no core operation they only emit the electric field because the bifilar coil accelerates the charges from one end to the other. This is done by passing opposite charges from opposite ends. As they approach each other they are accelerated out the other end via the induction of the opposite wind. This acceleration raises the voltage present at the charge.
Using traditional measurements and measuring instruments will not yield anything of value in my opinion. This is mainly due to the devices created for measurement were not designed properly for pure electric measurement.
Tesla was known to say that he didn't use the magnetic component in his systems designed after the AC system. The gain came from suppression of the magnetic field and only allowing an electric field integration. Since the electric field was mainly static as Tesla pointed out he had to find a way to modulate the electric field to cause a vehicle to generate from in the receiver. This was accomplished by the longitudinal modulation he employed and that naturally came from the use of impulses. Tesla quickly discovered that the speed of the electric field going from zero to maximum was faster then light. This is why he has said that light speed is not the fastest in the Universe. Since light is modifiable via magnetic fields it is not a huge jump to conclude that light is slow when compared to the electric field or transport medium of that light. In my opinion light is the result or wake of longitudinal rays-traveling radiative away from from a highly charged body in space.
Someone posted a great PDF of a NASA proposal to research this area of Tesla and others. It's in this forums download area and a link is provided in this thread: http://www.overunity.com/13149/nasa-report-on-teslas-zero-point-energy-page-41/msg357919/#new
learning as much as you can about Tesla/Dollard/Meyel and others will bring you up to speed about how to utilize the bifilar coil to it's full extent.
My original experiment is now being fully experimented on by me. Any information I can get out of the experiment I will share with everyone fully. Since the field coils in my motor generator will be Bifilar in design to handle the impulses to the field coils. There must be very little resistance of the wire in the bifilar coil because this will only slow down the impulses and the subsequent radiative field of such a coil. paralleling the coils will greatly enhance the impulse acceleration and hence the gain in voltage of the electric field. Also from the link I provided earlier in this thread you can see that any matter that is considered as conductive when exposed to this impulse field will generate huge currents in the conductor if the impulses are resonant with the mass of the conductor.
Well I'll let you get back to the road of rediscovery that you are on. Enjoy.
