Exploring the Inductive Resistor Heater
Started by gmeast, April 25, 2013, 11:43:17 PM
gmeast
Quote from: profitis on July 10, 2013, 07:54:57 PM
@gmeast.. cant post links coz im on opera mini compression on a phone.are you using lead acid batteries there gmeast.do they have openings that you can open up.theres a very nice way to gauge total power in lead-acid systems.
Presently I'm using the batteries I show on the forums.  They are SLA and/or AGM (Absorbent Glass Matt) and there is no access to the interior. What were you suggesting anyway ... specific gravity?
I'll post the Steven J. Smith link for you:
http://www.whale.to/b/magneto_thermodynamics3.html
profitis
yes i was going to suggest specific gravity or chemical test or conductivity measurement for varification of unchangeing electrolyte concentration post-run.chek out the 'self-charging electric car'thread where i give details for a spot chemical test for sulfuric acid gauging in the bats.if you want total absolute varification of overunity to yourself or to the public this is best way gmeast,to use lead-acid open type cells as the totality of power usage or gain is directly proportional to acid concentration.
gmeast
Quote from: profitis on July 11, 2013, 09:23:45 AM
I'm not sure this would be definitive in that the batteries are expected to discharge. It's just that they discharge less than would be expected.  I've been very careful to run the Inductive Resistor Heater tests head-to-head with straight-up ohmic loading. It's the comparison of these two tests that are vital.
profitis
@gmeast.i see what you mean yes.is your circuit recharging the bats at all? If its straight electric to heat comparison then these electrolyte tests wont do yes.if any circuits are selfchargn bats then its a genius method for total proof.even for sake of improved efficiency proofs.
gmeast
Just an update:
I'm still going to replace the batteries with a capacitor bank at some point, but the bank will have to be huge just to get a small enough voltage drop on the caps to allow for a a decent test duration ... hopefully 8-hours. If you examine the discharge curve for any capacitor you see it's the inverse of it's charge curve. On discharge, the cap voltage drops very rapidly over time for a given load. So the cap bank must be very big (wide - that is "parallel") if the voltage is to drop only .5VDC to no more than 1VDC over the test duration. As the voltage supply drops much below 24VDC to 25VDC, the performance drops off considerably. Lower voltage also affects the gate driver circuitry.
I'll first build a single 'series' bank for the supply voltage requirement (for 30VDC) and load it as I did during the battery tests ... around 3.2Watts. From this loading I'll be able to determine the rate of discharge of the bank for the particular capacitor specie. It then should be only a matter of arithmetic to scale the 'real' capacitor bank based on the same specie of capacitor. It could take well over 150 capacitor$ to get a sustained 3.2Watt draw for 8-Hours with only a 1VDC(max) voltage drop. It's possible to figure that out now just from the above requirements, but actual data is always best to have.
That's all for now ... only takes money.
Again, my video slide show "Preliminary Study of The Inductive Resistor Heater" is on my YouTube Channel:
http://www.youtube.com/user/gmeast
Thank you
