Big try at gravity wheel
Started by nfeijo, May 03, 2013, 10:03:04 AM
Quote from: mrwayne on April 09, 2014, 07:35:41 AM
To All,
One last time, I am going to pretend that TK, MH, ME, Liberia, Powercatt, Minnie, are not just Trolls getting their kicks off insulting people.
I will do this on Mondrasek's thread - the Mathematical analysis of an Ideal ZED - thread.
I am going to explain in super simple terms:
I will Explain what - I showed the first skeptic, why our engineers joined our team, what the Trolls completely missed or tried to  8) 8) 8)
Proof so obvious -
If it embarrasses those trolls - I tried over and over to warn them to try to understand - instead of attacking good people all this time.
WayneTravis
Why don't you just set up a webcam in front of your 5 hp selfrunner, powering a load, and let it run 24-7, streaming on the internet? Put a calendar-clock in the frame so we can see it's not a loop. After the third or fourth week of unattended running..... maybe even I would be convinced.
But of course I know you won't do that, and I know why. And so does every body else: YOU CANNOT... because no such thing exists, anywhere but inside your mendacious mind.
memoryman
TK, no offense take.
I completely agree with you assessment of Mark Dansie; I would not hesitate recommend having him do testing rather than me. I am competent: Mark is a pro.
As to trusting me for anything; it is up to you when/if you want to trust anyone. For me, trust is freely given, and can be withdrawn at any time by me.
camelherder49
Quote from: camelherder49 on April 03, 2014, 06:45:56 PM
My question did not involve how the water got into
a reservoir. The hydrology cycle takes care of that
very efficiently. Water recycling on earth is a given.
Water that falls into the great lakes region that passes
thru Niagra Falls moves from higher to lower elevations
by gravity other wise is would be static.
Water that falls into the City of New Orleans is static and moves from
lower elevation to higher elevation by a series of large pumps.
Obviously the water in New Orleans had no where to fall
but yet is was caused by the same sun.
If a ball is dropped from a plane gravity crashes it to
the ground. If you pour a glass of water out of a plane
then the sun causes it to crash to the ground.
tarakan
ARMCORTEX
You underestimate the advantage of mechanical devices.
To be a far initiate in electronics and gravity I say both schools of thought are evenly matched
I believe that gravity devices will win out vs quantum.
