BRAZIL - Company is building a Gravity Generator http://www.rarenergia.com.br/
Started by schuler, May 13, 2013, 09:19:51 AM
Sigh.
1. The google map link does show the correct location of the plant in Gilman.
2. We don't know what stage of construction the google picture represents.
3. The glowing dot in the photo of the building is certainly _NOT_ the Sun. It is a drop of moisture on the camera lens. You can see another one approximately centered in the photo, on the side of the building.
4. The RAR project has gone silent because finally somebody in charge realizes that it does not work and it will never work, because it cannot work, because gravity is a conservative field of force and cannot perform net work on such an object.
GraViTaR
Um, did you see my earlier post asking where the building is? http://www.overunity.com/13500/brazil-company-is-building-a-gravity-generator-httpwww-rarenergia-com-br/msg423000/#msg423000
The yellow circle is where the building should be. But from the interior pictures of the machine, the barn-shaped building in the upper left of the satellite image looks like it may be the actual building housing the unit.
We need someone in the Illinois area to take a drive out to 600 East Rd, Gilman, IL 60938 and see for themselves.
Take pictures and ask around. Be a detective. It's not that hard.
Zeitmaschine
Possible explanation of the modus operandi. Reply #21835 and Reply #21838.
Take a weight. Say 100 Kg. Suspend it on a spring. Now imagine there were a possibility to switch off Earth's gravitational field periodically with use of very little energy. Then that 100 Kg weight would start to swing up and down and we could use that momentum to do work.
So is there a possibility to switch off Earth's gravitational field periodically with very little energy? Yes there is - if the weight is the bob of a pendulum. When the bob reaches one of its highest points the weight of the bob is completely gone for a moment.
And strangely that gravity machine looks to me much like pendulums lined up in a row.
Red_Sunset
Quote from: TinselKoala on April 20, 2015, 09:41:07 AM
Sigh.
A good summary TK,
The Google Earth Satellite pictures can not show the building under discussion (most recent available picture on Google Earth is May2012).
The building and project was started after 2012.  A member of this forum has driven by the site and confirmed the buildings being there and posted pictures of it in "Big Gravity wheel".
Interesting how hypothetical negative everybody is about a new introductions, I would guess that human energy is also "conservative".
Some time ago I had a good look, wanting to understand how he inventor was trying to achieve the desired & needed gain in this gravity wheel configuration. It was obvious that his objective was to concentrate more weight/force in the down stroke compared to the upstroke.   A small marginal difference could be calculated but not sufficient to be positively in favor of solid rotation.
During the progress of the construction project one can observe modification/changes to the design of the weight bar, ( the left side of the picture with the weights on the ground)  It appears that here he was trying to find the advantage required for the upstroke.
A futile attempt in complexity in order to save the project I would guess,  an indication possibly that the writing was on the wall.
This concept is an extension of previous patented force enhancements with linkages, work done by Renato. As often said before in this forum, by notable members, "Force isn't Energy".
I think that like so many of us with a good idea, Renato thought he could swing that little remaining obstacle standing in its way in his favor.  I think he was sure he could beat it, because he was so close that he could touch it. Like Wayne I would guess.
What puzzles me that logically he builds a copy in the US of a working Brazilian version, but I believe this might not have been the case.
God's magic hand doesn't release the apple of wisdom to access "all power" that easily. ( I am sure Adam was already looking into "overunity" in those days)
Greetings, Red_Sunset
Zeitmaschine
God's magic hand ... bends down periodically this strong beam.
Supposed the only energy supply needed to keep that children's swing going is the energy that dissipates due to the friction of the pivot and the air. Then what energy is causing that periodic bending of that beam? Does God know?
So as it seems I was a bit mistaken about the spinning Whip-Top. That perpetual motion or so-called superior force, that children play in the lane with, is actually a pendulum or children's swing. But I was not really far off in that case.
Happy swinging :)
