Finally! Independent Testing Of Rossi's E-Cat Cold Fusion Device. Success?
Started by rukiddingme, May 21, 2013, 12:06:50 AM
Poit
"Should be revealed later this summer." ahhhhhh keeping up with traditations I see.... everything is always just around the corner..........
If you remember, Rossi's E-Cat was suppose to "reach market by October 2011"!!
in the free energy movement, there is no tomorrow, you either have proof now or you got nothing at all..
Zeitmaschine
Isn't that strange? A Pilot Customer for ECAT 1 MW plant is wanted in Sweden for »nothing at all«. ::)
MarkE
Determining output power using an IR camera is fraught with major sources of potential error.  Looking at their calculated values for radiated and convected heat one may observe that they had initial readings at ~800W input with reported 1733W radiated and 386W convected.  They increased the input power by 105W, IE and the convected values to 432W.   Input power increased by 13.1% and the calculated convection increased by 11.9%.  But the calculated radiated power increased to 2451W, a 41% increase in calculated output.  This strongly suggests that the calculations for radiated power are wrong.  Since the vast majority of output is based on the calculated radiated power, this is a major issue.
fritz
Quote from: MarkE on October 08, 2014, 04:08:06 PM
(..) They increased the input power by 105W, IE and the convected values to 432W.   Input power increased by 13.1% and the calculated convection increased by 11.9%.  But the calculated radiated power increased to 2451W, a 41% increase in calculated output.  (...)
To sum it up - you assume a strong nonlinear increase in COP as suspicious(!?)
The results are awesome - even if there would be an  systematical error of 50%.....
