Has anyone seen Lasersabers new motor runs on 1000uf cap
Started by Magluvin, May 25, 2013, 03:49:05 PM
conradelektro
Finally, DadHav's circuit for my little 6 coil pulse motor:
The circuit makes the rotor turn with about 120 rpm and consumes less than 200 µA driven with a 1.5 V AAA battery.
Note, no Reed switch, the coils are also the trigger via the second transistor.
The 2.2 nF cap (from the base of the 2N3906 to GND) is essential for clean switching.
The circuit stems from DadHav www.youtube.com/watch?v=8b4xlCKn3LQ and the transistors were chosen by Lidmotor http://www.youtube.com/watch?v=epWPTeV_544 .
Greetings, Conrad
P.S.: I posted a video https://www.youtube.com/watch?v=OqQSJjRJ6EQ
Magluvin
Quote from: wattsup on June 24, 2013, 12:07:58 PM
@Mags
Just got back late last night.
Sorry but my diagram is correct for the specific ozone patent 568177. It uses both the discharge on connection of a capacitor and the discharge of an inductor on disconnection to give two pulses while making sure the pulses are damped since for Tesla undamped pulses are always lost to the environment.
But again this method is very difficult to maintain because if the inductor is not of high enough inductance to create its own natural resistance, you will be producing heat. That's why I added that resistor in the circuit.
wattsup
Hmm thats odd. When I was working on the Igniter circuit, I could have sworn it was the same just different switching. Your right.  I dont think it would work though if the output/drive coil of the motor is used in series with the cap, being that the drive coil(of these motors) has high inductance already.
When the switch closes, the input charges up the large inductor through the output coil, of which it looks like a low inductance and not many turns in the pat.  Imagine charging up the large inductor then letting the collapse currents charge the cap through the output coil of these motors. I dont think it will happen like the igniter circuit could where it charges the cap in the input/large inductor loop without the output coil in the way. If the output coil is high inductance and ohms, it will more than likely act as a choke to the collapse current of the large inductor and end more with a spark across the switch instead I believe.
Have you tried the ozone circuit on a motor as you show?  I would be interested if it works. ;D
Got my 42awg wire in today. I had been playing with some relay coil wire till it came and this 42 is smaller. Near hair like. Its 1lb, supposedly about 50,000 ft. The roll measures about 85kohm.  Almost 10 miles long. Gunna take some pics for comparisons to 30awg, 26awg and the relay wire I was playing with.
Before I use any of it im going to try and see what kind of field and generator properties it has a a whole roll. Just for kicks.  ;)
I also have a compass module from a VW Touareg that has 2 coils perpendicular from each other and they are wound with even finer wire than I just received. :o If they produce voltage just from the earths magnetic field motion to provide input to the compass circuit, it will be interesting to see how much. The compass reads whether the vehicle is in motion or not, so it must be the coils are picking up on moving earth fields.
Will see.
Mags
Magluvin
Quote from: conradelektro on June 24, 2013, 03:11:59 PM
Greetings, Conrad
Hey Conrad
Does the motor work better with the 2.2 cap?  Was wondering if the noise is something that can be collected instead of snubbed with the cap.
Nice job. Ive been meaning to try Dads circuit.  I like it. ;)
Mags
Magluvin
Here are some pix of wire. First is a pic of, starting from the top  27awg  30 awg  then unknown from a relay coil, then the 42 awg, and finally, the bottom, one strand of my hair. ;D Had to do it. Sacrificial hair. ;D The hair is just about 42 awg, just a 'hair' thinner.  ;D
The next is a pic through a magnifying glass to get as clear of a pic as possible with this camera. It is of the 2 perpendicular coils of the electronic compass along with a strand of 42 awg.  The pic doesnt show so well, but those wires in the 2 coils are finer than 42 awg. With a 100x microscope the coils wire is almost half the diameter of the 42.
Then just 2 pics of the wire roll
Mags
Poit
"The circuit makes the rotor turn with about 120 rpm and consumes less than 200 µA driven with a 1.5 V AAA battery."
Please forgive my ignorance, naivety and assumptions.
If this demonstration draws less than 200µA, which is 200micro amps... or 2mA and spins magnets at 120rpm... my first thought would be, what happens when you introduce a generator coil either above or below the rotating magnets? Lenz Law kicks in right? but I would be interested to see by how much!
Say, you have a generator coil, how much more draw would there be on the AA battery? double? 4mA? 10 times?! 20mA? even if it was 10 times the draw, surely a generator coil could produce more than 1.5V @ 20mA? hence over unity?
**EDIT** I made a mistake! 200 microamps = .2milliamps!! not 2mA! wow! ok... thats even better!!!
