Two Antiparallel ignition coils
Started by Jeg, May 27, 2013, 03:15:40 PM
Qwert
http://en.wikipedia.org/wiki/Ignition_coil  >>  Construction:
"A single-spark system has one coil per spark plug. To prevent premature sparking at the start of the primary pulse, a diode or secondary spark gap is installed in the coil to block the reverse pulse that would otherwise form."
Jeg
Quote from: norman6538 on June 01, 2013, 05:18:39 PM
What kind of coil did you find the diode in?
Norman
Norman i didn't find it anywhere. I just confused it with flyback transformers, and that was in contrast to the anti parallel connection designs for making double voltage. Through output diodes you just double the pulse frequency as Tinsel said.
Jeg
