Advanced pulse motor with generator and BEMF collector
Started by TommeyLReed, June 02, 2013, 09:27:52 AM
TommeyLReed
This is a new pulse motor design using a 460v@5.3 stepper motor as a low rpm generator.
I'm using a pump circuit pwm to charge the secondary driver caps that is being powered with the primary caps  and small battery.
As the caps build up at a high voltage and discharge into the drive coils, the magnet repels that will turn a bigger rotor then the stepper motor assy.
The pulse will cause a BEMF that will also return back into the primary caps. The greater the load on the pulse motor, will also create even more return in watts due to load.
My youtube channel is HomeSchoolEngineer I am about to start the motor today...
TommeyLReed
This experiment show that Back EMF is extra power that can be use in doing work.
http://www.youtube.com/watch?v=2CmJnROjAfM
Tom.
