Magnet coil cores, demagnetization power and Lenz delay.
Started by synchro1, June 09, 2013, 11:07:49 AM
synchro1
@SkyWatcher123,
Thanks for trying. I'm glad I switched from Ohms to voltage to regulate the flux. The "Bucking Coil Inverter" looks really clean!
One final improvement:
I realized my DLE "Flux Controller Coil" needs a sister "Zener Diode" to channel output coil current to the storage capacitor, joined to the "Tunnel Diode". These two diodes would need to be connected by their input electrodes to "Fork" the current from the output coil. When the output coil voltage rose sufficiently, the "Tunnel Diode" would begin to restrict current flow to the internal electro-magnet core coil, as the "Zener Diode" opened up, permitting current to simultaineously flow from the output coil to the storage capacitor. Two seperate storage capacitors, offset in size with common grounds, might help. These "Symbiotic Siamese" diodes would combine to assist one another. They could nestle neatly together hidden behind a coil Wall. This finished coil would be difficult to tell apart from any ordinary coil at first glance. The difference is that this DLE "Synchro Output Coil" hides an intelligent core.
The "Tunnel Diode" can grow susceptible to back leakage after it reaches it's valley. A third standard diode in series between the electro-magent coil and it's charging capacitor would prevent this. I think that solves the entire problem. I would choose the same gauge enamel coated magnet wire for both coils perhaps 28 gauge, with a thin dielectric insulator between the coils. 1/2" high perm ferrite core with a few layers for the electro-magnet coil and a 2 to 3 depth to width ratio for the output coil. Plenty of thin wire turns! The core coil should have a N pole facing a N pole faceing out monopole rotor. Good luck!
This coil would be a major break through, have a COP of one over infinity, and replace nuclear fission if it worked as planned. A quantum leap in the field of free energy. Brace yourself for "Warp Factor Futue shock". Everyone has my blessings. May the force be with you! "Power to the People"!
SkyWatcher123
Hi folks, Hi synchro, i think i see what you are trying to describe, though some kind of imagery would help.
I decided to see if just one of the partnered secondary coils, the one under the bifilar oscillator, would light the led bulb the same and it did not.
It drew .7 amps and did not light the led bulb.
However, when i connected only one end of the other secondary coil, the wire end at the center of core, the led bulb lighted to the same intensity at the same amp draw of .52 amps.
Keep in mind, both secondary coils were in parallel to begin with, so why only the one coil would not light the led bulb is odd.
Not sure what to make of these observations yet, any ideas are welcome.
I wonder if i take only one wire from each partnered secondary coil and connect that to the led bulb, will it light at same intensity.
Which would basically mean, two open circuit coils.
Seems like slayer exciter behaviour a bit.
peace love light
SkyWatcher123
Hi folks.
Ok, i tried the open circuit wiring for each separate bucking secondary coil and it works.
With basically two open circuit secondary coils, meaning one wire end from each connected to the led bulb, lights the bulb to the same brightness as before, using same .52 amps, actually seems a little bit brighter.
I took wire end from coil under oscillator at end of core and other wire end from center of other coil and this is powering the bulb.
Any thoughts welcome.
peace love light
synchro1
These graphs represent the current and voltage of the Tunnel and Zener diodes: You can see how the turn on voltage of the Zener in red at the bottom, corresponds to the peak and current drop of the Tunnel in blue at the top:
The Tunnel charges the electro-magnet core which helps to lower the critical mínimum frequency for delayed Lenz effect. The rotor should be timed to speed up at the voltage peak in blue, at which time the tunnel starts to reduce current to the electro-magnet core to balance the increased rotor flux. The Zener begins to conduct the output  current at this point and sends it to the storage capacitor. This flux balancing should stabilize phase lag and sustain Lenz reversed rotor propulsión.
