Double Pendulum Power
Started by nybtorque, June 10, 2013, 01:03:21 PM
LibreEnergia
Quote from: TechStuf on October 23, 2013, 06:00:20 PM
Good find Kator.  There are numerous videos which point out the hilarity of hiding one's head in numbers.
The possibilities of resetting the device in that humble video demonstration alone, are numerous.
That is the funny thing about chaos.  It doesn't take much to cause many men's emotions to push their heads back under the comfy blanket of numbers.
Another funny thing about chaos.  There are hidden within, many, many forms of order.  Order which man is neither capable nor worthy enough to experience, for long.
Chaos that's consistently repeatable, is no longer chaos.
And our "chaos" is, to those who've gone before (way before), is among the simpler forms of Order.
Of course, once all is said and done, there is lower order and then there's Higher Order.
TS
Egregious bullshit. Even in chaotic systems , energy is conserved and this one is no different.
TechStuf
QuoteEgregious bullshit
Since you speak admittedly as a connoisseur, are you using the word egregious in the primary or secondary definition?  Just curious.  Definitions, like all other areas of reality, have a way of going round and round perpetually.
As for bullshit ..... there's "LibreEnergia" to be found in there too.
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
LibreEnergia
Quote from: TechStuf on October 23, 2013, 07:16:47 PM
TS
In this case it would not matter if it was the modern or archaic usage. The operative word is still 'bullshit'.
norman6538
Measuring this device could be done with a small weight on a string with a ratchet and then compare the distance lifted (work done) with the work used to cock and start the double pendulum.
I did this with a wheel version of the Milkovic device and did not find anything extra.
But the big problem is when you take work out of the balance or pattern you disturb that balance and tend to shorten the cycle.
Norman
TechStuf
QuoteIn this case it would not matter if it was the modern or archaic usage. The operative word is still 'bullshit'
We get it.  LibreEnergia sure knows his cases of bullshit.
You've already declared yourself an expert on the stuff...
Why rub it in?
