Double Pendulum Power
Started by nybtorque, June 10, 2013, 01:03:21 PM
TechStuf
QuoteThe physics simulation "Phun" or "Algodoo" even comes with a couple of Chaotic Pendulums as example scenes. If you think that the chaotic pendulum cannot be modeled mathematically... how does Phun do it, by smoke and mirrors?
Umm...actually......yes.  (It's ok.  The little things are easy to miss.)
Smoke and mirrors are a part of the process.  I assumed you knew?
But then, you know what they say about assumption....
Or maybe not.
TS
P.S.  Math is rather like the Heavens.  Only the fool thinks he knows any one part of it completely.  But one of many cases in point:
http://en.wikipedia.org/wiki/G%C3%B6del's_incompleteness_theorems
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
Kator01
@nybtorque
it works. see this french guy nicbordeaux. His channel:
http://www.youtube.com/user/nicbordeaux?blend=21&ob=5
Real motion-speed : three full turns !
http://www.youtube.com/watch?v=3EIikIEHqwU
Slow-motion-speed:
http://www.youtube.com/watch?v=5IO-Ui6tmko
I had a few mail-exchanges in the last year. This time he does not react for some reason..I do not know
Kator01
LibreEnergia
Quote from: nybtorque on October 23, 2013, 10:47:09 AM
What you and most other seems to miss is that the pendulums actually performs real work constantly; accelerating/decelerating mass; i.e. E(work)= m * a  * s. This is the work/power I calculate in the report, and propose might be partially productive (by replacing the mass by a resistive load or pumping water). And this does not violate the energy equilibrium.
I disagree. The system is given a certain amount of energy to start. After that this energy oscillates between kinetic and potential. With no friction it would continue forever. As such it acts as an energy STORE, but it is not GENERATING an excess of energy. If you bleed of the stored energy either by friction or using a generator, it will stop. The total amount of energy dissipated or generated will exactly equal the amount to energy given to it at the start.
Your proposal violates conservation of energy principles. Sorry, it just doesn't happen.
Your math is guilty of the same double counting error that Wayne Travis makes with his non working device, except your analysis is rather more complex.
TechStuf
Good find Kator.  There are numerous videos which point out the hilarity of hiding one's head in numbers.
The possibilities of resetting the device in that humble video demonstration alone, are numerous.
That is the funny thing about chaos.  It doesn't take much to cause many men's emotions to push their heads back under the comfy blanket of numbers.
Another funny thing about chaos.  There are hidden within, many, many forms of order.  Order which man is neither capable nor worthy enough to experience, for long.
Chaos that's consistently repeatable, is no longer chaos.
And our "chaos" is, to those who've gone before (way before), is among the simpler forms of Order.
Of course, once all is said and done, there is lower order and then there's Higher Order.
TS
vince
Single arm version of nybtorque's double pendulum continuos drive machine.
Anybody curious? I was.
Vince
