Amazing Coil puts out 200 V
Started by FatBird, June 11, 2013, 01:48:51 PM
Quote from: Magluvin on June 11, 2013, 07:41:28 PM
Well, one way or the other, powered or self powered, I wouldnt want to touch it. 200v is 200v. So thats not an indication of a fake really. Not that Im saying its real. ;D
http://www.amazon.com/Volt-Trouble-Light-Extra-Bright/dp/B009IXTD76/ref=pd_sim_sbs_hi_1
What makes you think that there are 200 volts involved? I see no meters, no indication that that is actually a 220 volt bulb. It could easily be a 12 volt automotive trouble light bulb.
Plus, why put the power from under the table across the coil at all? If it were, the light bulb would not be the only thing glowing. :o ;)
So I would venture to say that if it is powered from below, the coil is probably insulated from the power supply at both ends. No sense in even connecting one end of the coil to one side of power if not connected to both ends of the coil. ;)
Mags
That's right, the coil itself is not connected to the incoming power. It may be at the far end, but at the near end you can see something fishy right at where the coil begins. A blob or knot of something. It would be easy to make the incoming power connection here, only to the flex lead, and not to the coil itself.
When I did this for the first guy's video where the alligator clips are crimped to the coil ends, I just put some transparent heatshrink over where the crimp would be, so that the clips didn't actually make electrical connection with the coil's wire. The incoming contact points then contacted the alligator clips from underneath , and the coil couldn't short out the power because it was insulated from the clips. A similar arrangement is probably used here.
Magluvin
Quote from: TinselKoala on June 11, 2013, 09:49:27 PM
Just going with the title. Nobody knows anything really. We can only guess. ;)
Mags
conradelektro
Quote from: MileHigh on June 11, 2013, 05:35:49 PM
Probably the most important question for both of you is this:  Why were these clips faked?  What is a possible motivation that these people could have for faking these clips?
I think in this case it is like the show of an illusionist, like making a lady float in the air or sawing a person in two on stage. Nowadays the stage is YouTube.
And of course, it is a pretty lame show, like making a coin disappear with the wave of a hand.
Greetings, Conrad
stprue
Fake:
Why do people keep looking at this crap thinking its real.  This guys tricks were already outlined half a year ago now.
FatBird
When are you IGNORANT "Nay-Sayers" and Trolls going to WISE UP?
If you watch this video, it PROVES that EVERY magnet has a ROTATING MAGNETIC FIELD BUILT IN.  It rotates FOREVER at Light Speed.
The Plasma Mug ILLUSTRATES how the North pole has a Clockwise ROTATING Magnetic Field, and the S Pole Counter-Clockwise, INHERENT WITHIN ITSELF.
Therefore, the magnets he places on the ends of the Coil PROVIDES ITS OWN ROTATING FIELD Forever.  NO MECHANICAL ROTATION NECESSARY.
PLEASE WISE UP FOLKS.
http://www.youtube.com/watch?v=afQW8FT02DM
