Tragic accident with ball magnet EMDR motor-generator
Started by hartiberlin, June 22, 2013, 03:08:34 PM
twinbeard
Yeah, watch the videos that came after that one.  My instrumentation got better as well as the device, and my understanding of the processes evolved.  You will find answers to your objections there, because frankly, I have heard all this crap before.  Quite a few very intelligent people well versed in the applicable physics have seen the device in person, and examined it.  Not one has questioned the frequency of operation, particularly after hearing the air ripping around the rotor, which, alas does not come through in the videos due to ambient noise, the fact that I like to play music while making videos to have a background soundtrack, and the lack of a studio quality mic.  Per friction... it atomizes some of the lubricant, but not all.  Eventually the lexan tube the rotor is housed in fails as a fine powder of lexan is produced over time.  This does not happen in all instances, as occasionally the rotor will essentially suspend inside the housing, causing only air friction.  But none of that matters, really, because you opened the conversation by being an asshole.  Learn some manners, and perhaps you might learn something, if that is indeed why you are here.  Time will tell if you a genuine or just another paid shill... a common play from a tired playbook that I am WELL versed in applying countermeasures against.
Do you really think people have to be paid to "debunk" your video?  Your clip was cited by Synchro1 and you inadvertently got dragged into the discussion.  My original comments on your clip are true, as you are basically acknowledging that right now.  You got vulgar hence the detailed response.
I did look at one other video of yours, and you fail to decipher what your scope is telling you.  It's a common "waveform within a waveform" pattern that any experienced person would recognize.
This clip:  https://www.youtube.com/watch?v=XIZDu7HFmJI
Note my comments in the previous posting before I even looked at this new clip:
QuoteIt looks like a compound waveform of some sort, perhaps two separate sine waves added together, with "low" and "high" peaks along with some amplitude modulation as the two sine waves beat with each other.
See the attached pic from the new clip.  That's essentially what you are looking at the whole time when you play with the base resistor value.  You just have to know how to trigger on it.   In this case the waveform did the triggering on you.  It's a very old clip and for all I know you have gained a lot more experience and knowledge since then.
Back to you:
QuoteFeel free to replicate what I built, if you can.
I haven't worked seriously worked on an electronics bench in 20 years and I can still spin circles around you.  No offense but just keeping in real and let's just turn the page.   I don't even like electronics anymore and for what it's worth there are some people here that can easily spin circles around me.  It's like a Richter scale and I am not on top, that's for sure.
If someone makes a reference to a YouTube clip as being amazing and the clip is a mess, sometimes I will point that out.  I only do it occasionally.  It's for the good of all the readers and specifically it was for Synchro1's benefit.  Sorry it tasted like cod liver oil but Synchro1 himself can be like cod liver oil.  It was not directed personally at you.  Your clip just happened to be the one that was cited.
You absolutely need a second method of measuring the speed of the spinner. The assumption that the spinner is spinning in 1-to-1 synch with the drive pulses is just that: an assumption. Until you get a valid second type of measurement that confirms that you can use the electronic signal, you simply don't know.
synchro1
@Piratetwinbeard,
I have been deeply inspired by Jerry Bayles and his Chiral Homopolar balance magnet oscillation demonstration. Jerry has determined that longitudinal magnet waves describe a vortex based on a Phi or a Fibonocci series like the plant image below: My current theory is; That this kind of wave vortex, with the poles trailing one another at 180 degrees, spins the neo magnet faster then the applied pulse. My point is, it may be feasible to help predict spin rate with theoretical mathematics, along with our imprecise analog testing techniques. This may act as a "Second Method" for calculating spin rate.
synchro1
"Each Phi spiral is actually a series of pure sine waves. It is a well-known principle in physics that any complex wave shape can be created from the sum of simpler pure sine waves with different frequencies and amplitudes. This principle is called the Fourier principle. The Phi spiral is constructed from a series of harmonics with wavelengths that comply with the Golden Mean version of the Fibonacci sequence":
Jerry Bayles Chiral Homopolar balance magnets oscillate at the Phi resonant hertz as predicted by the bottom graph! Gravityblock noted that Jerry's balance magnets nearly tore off the test bench at 1.618 hertz!
