Rosemary Ainslie Circuit Demonstration June 29, 2013 Video Segments
Started by TinselKoala, July 01, 2013, 08:17:22 AM
powercat
Great news, the suppressive self righteous delusional propaganda forum has been suspended  :) ;D
what will she do now,  admit she was wrong or run away.
poynt99
Here are the 3 latest video links in case those reading here missed the posts on my thread:
Grounding problem and solution:
http://www.youtube.com/watch?v=0rtuSwfs-90
Correct location for the FG reference lead:
http://www.youtube.com/watch?v=e_ZK6OPJLl4
Pbat measurements - wrong, better, and correct:
http://www.youtube.com/watch?v=WXdsXvq6QAs
Poynt Ninety-nine!
About that schematic.  It's amazing.  I see voltage "falling" as you move from the top of the schematic to the bottom.  It's like a beautiful waterfall!!!  The music of the spheres!!!  A soft parachute landing!!!  I can save brain power looking at your schematic as compared to a regular schematic because there are less contortions and twists to deal with!!!
Conservation of brain power is very green because the brain consumes energy!
QuotePercent of total body weight that the brain represents     2 %
Percent of the body's oxygen consumed by the brain     25 %
Percent of the body's glucose burned up by the brain     70 %
You are really and truly an innovative expert!!!   ;D
Farmhand
Often times people are tricked by the effect of a Lead Acid battery's effects when being discharged.
At first the voltage drops to a certain point then as the chemical reaction catches up the voltage rises while under load to it's actual voltage under load.
Sometimes this can show a battery initially drop from 12.6 volts to 12.3 volts in quick time but then after a minute or so the battery voltage will rise again as the chemical reaction
catches up to the draw on it. When that happens it looks to some as though the battery is recharging, and if when the battery first returns to the maximum voltage under load the load is removed, then the battery voltage rises due to the continuing chemical reaction, at certain times I have been able to observe a higher voltage on the battery terminals after disconnecting the load than was at the terminals before loading. However energy has been removed from the battery and it's charge is reduced. With some batteries if done just right this happens but the voltage always settles back to the same or less than it was before loading after some time. I guess it could be called electro-chemical hysteresis or something.
The effect tricks a lot of people. Including he 3BGS crew. Lead acid batteries can have some interesting effects or what may seem interesting at first, but after careful consideration make perfect sense.
I still don't see how anyone that matters could take her seriously. Especially without a self runner. By saying that I mean the things posted on these forums have little to no effect on mainstream science. By saying the "people that matter" in this case I mean, investors and third party examiners of the device. Everyone matters in some way it's not a put down to any trained guys here.
I think you guys have successfully exorcised this demon. Who is next UFO politics ?
Keep it up guys, I would hope you guys would exorcise all the demons infesting these sites.
Or is it Just Rosemary ? Are all the others OK to continue ?
I'm sure if I put my mind to it I could come up with a list of high profile more out than in claimants.
What about Aaron and his over C.O.P. 1 bouncing ball rubbish.
Or Eric Dollard and his free energy relay that supposedly "synthesizes" extra energy. I think that is his only claim of extra energy funnily enough.
And yet he denounces the free energy gurus "he says" to distance himself from the dramas, but he is in league with them and claims similar things.
I think Thane is done for. Needn't waste time on him. Even I can produce demonstrations to look him look silly.
If I was well trained I would rip into the rest of them as well. In my opinion they are conmen bordering on criminality.
Cheers
poynt99
Thanks MH. Here is the next one:
Two potential sources of measurement error are examined; parasitic inductance (we've looked at previously) and induced emf in the scope probe ref leads.
http://www.youtube.com/watch?v=aQKm0qVUCkk
