self charging electric car
Started by dreamyear, July 10, 2013, 09:24:58 AM
markdansie
@Profitis
Hi mate I might look at this which is similar why I am here
So I want you to design the tests lol.
http://revolution-green.com/2013/07/10/self-looped-motor-generator-philippines/
Kind reagards
profitis
hi mark.i hope he has open-type lead acid cells so that you can take a hydrometer along with you and spot-test the specific gravity of electrolyte in each compartment before and after a nice long run.hydrometers should be cheaply available at the local garages.if those are closed-type cells we gona hav 2 figure a other way or you could ask him to hook it up to open lead-acids 4 the analysis
profitis
@markdansie..another very smart way to test lead-acid systems is to get hold of some lead nitrate crystals,disolve in water(20-30 %),half-fill 2 equal size test-tubes,add 5 drops of test-sample battery acid to one testube prior to run.add 5 drops of acid to other testube after run.let testubes sit deadstill for few hours uprite and chek volume differences of lead sulfate precipitate btween the two.if its same or if more volume in testube 2 its nobel prize.if its less in testube 2 than testube 1 then time wasted.
AetherSea
Quote from: FatBird on July 10, 2013, 02:00:05 PM
This man had an Electric Car too, but they done him in.
http://www.youtube.com/watch?v=jeKnDxWRHYI
Fatbird
Nobody did him in.   Troy Reed was a liar and admitted himself in 1999 that the motor was not self sustaining.  Another scammer that tooks thousands of investor dollars.  The electric car had so many batteries in the trunk it barely cleared the ground.
http://peswiki.com/index.php/Directory:Surge_Motor_Technology_by_Troy_Reed
