self charging electric car
Started by dreamyear, July 10, 2013, 09:24:58 AM
dreamyear
it's really simple........ i u have question... comment on youtube.
Quote from: FatBird on July 10, 2013, 10:14:43 AM
Is there anybody that can post a Better schematic?
The one in the video is fuzzy & blurry.
e2matrix
I commend your diligence in trying to get more out of batteries but I think you may be fooling yourself about actually having a self charging device.   The higher voltage on the battery does not always mean higher capacity.   Does the voltage stay higher as seen in the video if the battery rests for about 24 hours?   You say it won't run forever.   Of course not but can it run for a couple weeks without needing an external charger to bring the batteries back up?   Do the batteries run a motor that moves the 'car' or are they just running the motor that has a cam which triggers the relay?
FatBird
markdansie
@ Fatbird, they actually confessed in latter years it was fake.
How did you miss that one.
@Matrix, you are correct
e, but it can do for a while.
The spike either desulfates of changes the plate architecture.(increases reaction area.
This is great for a short while.
This current device is not unlike many motor generators. The higher voltage does not indicate greater battery storage
Mark
profitis
surface area changes may be happening but the important factor here is total power.the advantage of using lead-acid bats is that one can guage the total power in the bat by measuring the sulphuric acid concentration in the electrolyte.if it goes up more than you started with or stays same you have a nobel prize.a highly sensitive ph meter suitable for high acid concentrations will be useful.a highly sensitive conductivity measurement of the electrolyte will do aswell.a direct chemical test for sulfate ion concentration is another opt(you need some lead nitrate for this)
