Agha Waqar running Car on his HHO Fuel Cell
Started by Paki1, July 14, 2013, 10:26:30 AM
Kator01
profitis,
yes true, just uploaded a file : Bockris, on the splitting of water. Go to the download-section
http://www.overunity.com/downloads/#.UhJJC38w6uI
Kator01
profitis
bockris is a genius @kator,however no fuel consumption is required in my above example,one can use 2 smooth platinum electrodes with same result,electrolysis and splitting of water at 0.5 volts,at a slow pace.give me a fuel cell @kator and i,l use it to split water fast with my secret electrodes(-:
Kator01
profitis,
I have two carbon rods ( saved from an old Zinc-Carbon battery ). Do you mean carbon or graphite ?
I will give it a try. Salt-Concentration necessary for this experiment  ?
My understanding is that this is the standard chloralkali-process: Using salt-water you will get cloride which will form H2, O2, Cl2 and  OH-, ClO-, ClO3- , so you have to be careful and ventilate your room.
Why no fuel-consumption since H2 is formed ? In addition you will get NaOH but only if you use a membrane
http://en.wikipedia.org/wiki/Chloralkali_process
Or do you mean no consumption of carbon ?
Kator01
profitis
yes kator no consumption of carbon necesary.carbon is actualy very unreactive at room temperature so it will do fine for the experiment.you can use sodium bicarbonate or sodium hydroxide aswell then no chlorine will form,just oxygen and hydrogen.every single electron that passes through the cell has no choice but to split water(faraday,s law) so try to measure the current that passes on a milliamp meter,and multiply by time and then we work out how much gases formed.make sure your carbon rods are totaly de-waxed by holding them over a candle flame with pliers and burn the wax off kator,one end then the other end,for maximum surface area and to un-waterproof them.use a high concentration of electrolyte for the experiment.what are you going to use as your power source kator.
markdansie
@profiis
go do some homework. Introducing other elements like Urea to teh solution can lower the voltage required for electrolysis down substantially (possibly bellow .5 v) You can also introduce alcohol lol.
I admire your free thought and imagination but please do some practical experiments and report the data. As far as this Pakistan Car goes its is 100% bullshit, he has been exposed, denounced and the track record still stands water powered cars 0/ science 100
People hear grab a headline or a story that matched their belief system and often choose to ignore all the other over whelming evidence against.
mark
