Agha Waqar running Car on his HHO Fuel Cell
Started by Paki1, July 14, 2013, 10:26:30 AM
markdansie
@ Kator01
As always show me the data and a good methodology of gathering it and I will always bow down to it.
String together a lot of data from various sources and string them together into some theory and I will admire the effort.
But it is always important to test such assumptions.
I will give you an example.
Many years ago I worked in fuel efficiency  research. The persons i worked for believed if we strung 3 or more technologies together we would get an accumulative effect.  Was good in theory but when it came to the tests it never panned out. Why?
I really like what you are proposing , but show me the data that is generated from and actual experiment that is over 100% efficient, not just assumptions made in theory.
PS I know about graphene lol
Keep up the good work
Kind Regards
Mark
profitis
exellent info @kator.we are definitly on the same wavelength.markdansie wants to see the layouts,which is understandable but we dont want others who are eyeing this thread  profiting while we do the work.ive given markdansie so many pointers,without diverging from text-books,that if he hasnt clicked on by now i dont think he wil.i gave him faradays law and a self-charging fuel cell experiment to do at home.that should be sufficient to trigger him to dive into experiments.true @kator,work function is definitely a role player.the important thing to understand is that your experiment that you did for us produced exactly 0.5 volts worth of adsorbed h2 + o2.if you had let it rest for a little while the atoms would combine into molecules and the back-emf wouldve subsided,allowing you to repeat the cycle,repeat,repeat,repeat.the time lag between repeats is the critical factor for rate.the materials that you use reduce time lags.carbon realy sucks but its good enuf for demo.
profitis
@kator..im truly beginning to see the benefit of pulsed currents,im picturing in my mind how even a slight inductor backspike would cause some re-combination of adsorbed H2 and O2 into water giving a clean sweep of the electrodes surfaces to enable the next cycle.it seems one can actualy manipulate how much of a saturation one wants,then pull the rug out from under it.
markdansie
Quote from: profitis on August 22, 2013, 09:27:25 PM
This is an open forum Overunity thread.  You are  starting to sound like Sterling Allan.
profitis
indeed @markdansie..i,l give an arm,not a leg too.will you fill us in on the details of the magnetic field on the h2 electrode?
