Agha Waqar running Car on his HHO Fuel Cell
Started by Paki1, July 14, 2013, 10:26:30 AM
Kator01
Quote from: profitis on August 22, 2013, 10:56:55 PM
@kator..im truly beginning to see the benefit of pulsed currents,im picturing in my mind how even a slight inductor backspike would cause some re-combination of adsorbed H2 and O2 into water .....
profitis,
did´nt tinman show a vid about his copper-zin-cells where he used the collaps-emf ( not
back-emf..it is something
different ) to regenerate the cells ?
I can not find it anymore.
Anyway I try to elaborate a circuit.. not so easy as one thinks.
markdansie
Quote from: profitis on August 22, 2013, 11:44:31 PM
indeed @markdansie..i,l give an arm,not a leg too.will you fill us in on the details of the magnetic field on the h2 electrode?
There are three streams of research in this area.
1. The first one is in Europe and I am under NDA. I assisted the researcher to obtain if I remember correctly around $13,000 for further experiments. They are still in progress and getting not what we expected, but a whole lot of other areas to now further research. It uses oscillating magnetic fields for splitting water. Requires some pretty cool preconditioning but requires no electricity after initiated
2. The second is in the USA. I have distributed to a few people here a couple of videos of that in operation. That used a non pulsed magnetic field with electrodes in a hydrogen environment. Several people are in various stages of reproducing that experiment and if we get confirmation that will really open up some doors. This does not make hydrogen only electricity. We are not sure if hydrogen is consumed in the process as of yet.
3. The final one is a variation of the nuclear spin device. Will get back to that next year
Kind Regards
tinman
Quote from: Kator01 on August 23, 2013, 06:36:15 AM
profitis,
You mean this one.
http://www.youtube.com/watch?v=64EDo4OB_L0
It kept on running until the water leaked out of my(no so well sealed)cells,and turned the MDF to paper mush lol.
Anyway,you will be seeing a better version of this in the Pulse motor build off-no leak's this time.
This video was actualy the first time Mark contacted me via email-so it got his interest anyway lol.
The theroy was proven to be sound,and the plate deterioration was almost nil on the JT over 7 weeks running. Mark also has a water powered torch,and who know's-maybe it has somthing similar to this incorperated into it,to make it run so long on one cell?.
But there is a better liquid to use other than water,and increases each cell voltage to almost 2.1 volt's,where as with water,this type of cell only produces around .8 volts.
But rather than just post theroies and make claims-i prefer to show actual working devices. This is something some others here should try once or twice. It's called-putting your money where your mouth is.If it's not yours to share,then fair enough. But i see many claims made by a few here that have nothing to back up said claims with-just talk,talk,talk.
Sorry guys,but im with Mark on this one-show us a working device.
profitis
@kator yes i think tinman is on the money there. If you were to take a zinc-copper couple in acid,and put an inductor circuit of some sort between them as your bridge then the much-hated buildup of hydrogen back-emf-polarization can be alleviated to some degree by the back-spikes,cleansweeping the copper surface from atomic hydrogen,allowing for some renewed surface area.it would work better under alkaline conditions due to faster seperation of h2 bubbles from wetting ability.
profitis
@markdansie..if a stationary magnet effects the electrode potential of a hydrogen electrode then yes,we can build a cell with two h2 electrodes.some quick googling indicates it does indeed.
