Gravity CAN do Work
Started by mondrasek, July 19, 2013, 12:36:42 PM
tim123
I've done a few sims in Phun and Physion. Phun, in particular, has a very good UI, BUT I've always felt they weren't very lifelike. Now I know why. I read about the 'Fifth Element' years ago, and just spent an hour re-educating myself on this excellent website:
http://www.halexandria.org/dward124.htm
Basically, sims don't include the *rate of change of acceleration* in the force model. Because mainstream physics doesn't. So they're mostly useless for OU purposes.
Davis & Stine's work is brilliant:
http://www.halexandria.org/dward138.htm
"The profound result of their analysis and supporting experimental/experiential evidence is that an oscillating force with a frequency comparable to the inverse of what Davis referred to as the Critical Action Time (and what is referred in Connective Physics as the time delay of The Fifth Element) can be applied without the resulting action/reaction force of Newton's Third Law coming into play.  In effect, according to Davis, "You can get away with anything provided you don't get caught while you're doing it, and you leave the system immediately thereafter!"
Not sure it's relevant to your lever Webby, but thought I'd mention it.
tim123
So you're lifting 2600g with 1740g, both moving by 4 inches?
Sounds promising... :)
zoelra
@Tim123,
A hi-speed room/box fan (preferably metal with metal blades) is great to experiment with.  If there is a handle on top, raise the fan slightly off the floor and rotate.  You can feel how the gyro forces redirect the fan.  Try to duplicate the motion Laithwaite shows in his patent and see if you can feel the upward force (or reduction in weight).
tim123
Hi Zoelra, thanks, that's a good tip.
I'll definitely have to build a powered, high-speed gyro, just for fun. Only a couple of weeks and I'll have a functional workshop, with doors...
Laithwaites design for a reactionless drive wasn't ideal for land-based craft, but it was a good starting point. Perhaps the effect could be used to drive a 'flying car', but it may be difficult to engineer.
The 'Dean Drive' is another - it doesn't use gyros, but eccentrics:
http://www.inertialpropulsion.com/dean_drive.htm
Neither of these, however are really gravity-powered, or OU...
Gravity Can Do Work...
The only possible ways to get gravity to do work, as far as I can tell ATM, are
1) Use a 'gravity shield' - e.g. Podkletnov, Keeley(?).
2) A system of varying inertial frames / reference points. This is only a Bessler-inspired conjecture TBH. I'm sad the RAR Energia seem to have hit problems.
3) Electro-static-gravitic lift - e.g. T. Townsend Brown, 'Lifters'. I assume that this can be made OU - as it's essentially an electrostatic effect... Not sure it's strictly gravity though...
Hypothesis: How Electrostatic Drive Works
Here's a hypothesis for where the lift in (3) comes from: By biasing the natural quantum fluctuations in the material.
- Quantum transposition is constantly happening, and a strong electrostatic field affects the probabilities of where things will 're-appear'.
- Electrons (-ve) will tend to re-appear towards the +ve pole of the field, and atomic nuclei (+ve) the -ve.
- So electrons, in the course of their orbit, will tend to miss out part of the orbit where they are moving toward the -ve pole of the electrostatic field. They will 'jump' to a more 'likely' orbit. So their centrifugal force will be asymetric - i.e. toward the +ve pole.
- Electrons, could also tend to re-appear in a higher orbit (shell), which would decay - resulting in fluorescence that apparently is observed(?)
- The nucleus, would tend to appear towards the -ve pole, and would then tend to 'spring back' to the center of the atom. If this is repeated at the top of each rebound, I think it could result in a 'Dean Drive' like effect on the atom as a whole.
Just thought I'd throw that in...
telecom
The website of interest is http://www.blazelabs.com/
Unfortunately he closed the yahoo group - there were many very interesting posts there.
