New Rosemary Ainslie Demonstration Scheduled for Sunday, 4 August 2013
Started by TinselKoala, July 29, 2013, 03:48:24 AM
SeaMonkey
Quote from: Tseak on August 14, 2013, 12:33:55 PM
TK,
You're incorrigible. ;D
http://www.youtube.com/watch?v=1s9z620SFbA
And, it must necessarily be added,
The King of Hyperbole!
That is a dominant characteristic of
those who come from Our Home Planet.
(The video was good!)
conradelektro
I can hardly believe it, Ainslie admitted an error?
The many tests, contraptions and measurements (scope shots) done by TinselKoala finally helped to find the truth behind these wild claims.
The truth was know almost from the beginning, but only TinselKoala had the will and determination to educate enough people to stop a deluded person from proliferating this nonsense.
But now, no more time wasted on Ainslie!
I think that TinselKoala has the knowledge (because he built spectacular Tesla coils) to deflate Ernst, the self proclaimed Wardencliff resurrector and Tesla theory preacher.
Look how Ernst wallows in his self injected fame, without giving any proof, just by waffling and alleging:
http://www.energeticforum.com/renewable-energy/11952-wardenclyffe-teslas-true-intention-19.html
Greetings, Conrad
Let Ernst play, he's another UFOPolitics, thrives on his following and his drama. He can parrot big words and calculations all he likes, but he apparently still can't show a real measurement or a coil that outperforms any of mine. Wake me up when he shows some significant power transfer, without making every metal bit in his environment spray corona.
And really, I can't seem to claim much credit for Ainslie's rather insincere capitulation. I don't think she has actually watched any of my videos! Not since years ago. I did, indirectly, start the chain of events that brought Steve Weir to the scene, and it is poynt99 and Steve Weir who really deserve the credit for bringing Ainslie to this point. Perhaps my continual harping on the Figure 3 shot brought her around to the decision to have a public demo, in an arrogant effort to put me down.... but like all megalomaniacs she could not even conceive that she could have been wrong, so for more than TWO YEARS she never bothered to check or ask someone she trusted, she just insulted and claimed and insulted and threatened, until finally her ego couldn't take it any more and she had to try to put me down publicly, without even checking to see if she could do it, first.
Anyhow, Steve Weir deserves major credit even though he is a total newcomer and isn't fully aware of Ainslie's depths of duplicity, along with Poynt99 who also has a special relationship with Ainslie, so that she at least tries to understand his explanations. I just rattle cages, at this point.
gyulasun
Quote from: SeaMonkey on August 14, 2013, 01:24:39 PM
The final paragraph addresses a potential
problem with the concept.  Can you come
up with a solution to overcome this problem?
Hi SeaMonkey,
Well, if you mean the divison of the supply voltage between the heating element and the series inductance as a potential problem with the concept, then I do not think it could be solved. If you meant something else as a concept problem, please tell.
It is obvious that the total power dissipation should include the entire circuit. The selection of the MOSFET type (with the 2 Ohm ON resistance) by the RA team back then did confine efficiency for the lower ranges, well below 80% (if the heating element had a 10 Ohm resistance).
Here is a device from Linear Tech which has 98% efficiency (i.e. COP=0.98) at certain output power levels and uses sophisticated switching and circuit technique: http://cds.linear.com/docs/en/datasheet/3780ff.pdf (I have no any connections with Linear Technology.)  Here is another device of 98% efficiency, using syncronous rectification: http://www.linear.com/product/LT8705
rgds,  Gyula
profitis
@sea monkey..aye, tis the crux of the matter sir,the inductor itself.i propose radical new efficient methods for testing of inductors,inductors alone with their kickbacks.it will cut out the necessity to build an entire circuit,only to find out that theres losses later.some sort of meter with variable oscillance,variable diodance,plotting power out/kickback in,all-in-one.in other words all you will need to attatch to the machine is your inductor..something along these lines.. standardization of some parameters instead of chaos of all parameters
