CYCLICAL GRAVITY SLIDE ENERGY GENERATOR / EXECUTIVE TO
Started by netwebresearch, April 14, 2005, 10:40:57 AM
0 Members and 25 Guests are viewing this topic.
netwebresearch
I have invented a new renewable energy device. The device is a CYCLICAL GRAVITY SLIDE ENERGY GENERATOR / EXECUTIVE TOY. The device works by a wagon rolling round a track. The track is slanted downwards for the vast majority of the track, then the track slants upwards for the track to join together. So the wagon can roll round the track again. The reason the wagon can roll round the track is that as the wagon rolls downwards the wagon generates electrical energy. Then the momentum of this downwards roll carries the wagon up some of the upwards hill. Then the wagon is pushed the rest of the way due to some of the electricty gerneated by the roll down of the wagon down the track. The track works a bit like a bobsleigh except with the bobsleigh using the momentum of the downward run to be pushed up some of the hill again.
My solution to this problem is a device that allows a wagon or ball to roll down a track generating electricity as the wagon rolls down the track. Although it is a fact that it takes more or an equal amount of electricity to push a wagon up a hill than would be generated by the wagon rolling down hill. Momentum from the wagon rolling down the hill would still be large enough to raise the wagon a fair distance of the hill. So not all energy generated, from the wagon rolling down the hill, would need to be used to push the wagon up the hill. The momentum energy from the wagon rolling down the hill and the energy generated from the wagon rolling down hill should exceed energy to push the wagon up the hill. So this system can produce an electricity  surplus for other purposes. The larger the wagon and track the more energy produced.
Kysmett
There will be a resistance as the wagon rolls down the hill equal to the sum of total friction and an added generator.  That will limit the wagons speed as it approaches the upslope such that the enertia that you are counting on to carry it up the hill to the point that the charge will suffice to get it over the hump will not be reached.  True it will get farther than if you were not generating a charge, but in my humble oppinion will not be enough.
hartiberlin
This would only work,
if you have designed a generator that has no drag back effect,
but normal generators must by pushed with more energy, than they
generate in electricity... so this will not work
with normal generators !
Regards, Stefan.
netwebresearch
Does the device have potential for research though. How about if the slopes upwards is also lubricated to decrease friction.
FreeEnergy
how about using a neo magnetic sphere that rolls down the hill and as soon as it starts to roll up hill it goes into a thick copper pipe to go uphill? from what i understand when a neo magnetic sphere enters into a thick copper pipe it looses weight i think. so wouldn't it be easier for the sphere to go up?
