Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 58 Guests are viewing this topic.
Void
Hi Clarence. Not sure if paralleling the two battery chargers will work. The two separate battery chargers will
be trying to regulate their output voltage/current separately, meaning they may be constantly trying to adjust their
output voltage/current relative to the other, and this might not give desirable results. It might work though. One somewhat
larger capacity battery charger might be better.
P.S. Ok on your ground where you have your ground rods being really soggy. I never imagined it was quite that swampy
on your property, but I have never lived in swamp country.  ;)
All the best...
Clarence
Quote from: Void on February 08, 2015, 10:04:00 PM
All the best...
Clarence:
Hello Void, a.king21, & ALL,
just a quick update so you won't think I fell off the earth. my supplies for installing SIX more ground rods as an
addition to the previous eight wont be in until Thursday of this coming week. I should have them installed and
ready for testing by Monday the 23 rd of this month.
In the meanwhile I have been testing the existing EIGHT ground rod return system to gain some type of reference data
to use against the newer 14 rod system when I get it installed.
I disconnected the Ground Grid System completely from the system as a whole. then I connected my Fluke 77IV Multimeter
to read DC voltage and connected the positive probe to the eight rod return source and the negative probe straight into the
earth soil and the indicator quickly started to rise and slowed and settled out at .400+ volts (I say plus + because I took
MANY readings, morning, noon, night, evening, midnight. etc. with the readings going to .420-.450-.430-.415-.470 and
points between) so I chose the LOW reading. All of this effort to get to a point!
I divided the .400 by the eight rods in the system providing the reading which gave an average of .05 DC volt potential per rod.
Now to explain where I was going with this process.
Since the B&L device was using 40 rods to have a fully capable and viable device OPERATING AT 220 VOLTS that would mean
that their system was receiving from the earth 40 X .05 = 2.0 volts as a low voltage carrier supply.
My system is A 120 VOLT SYSTEM  so I should need roughly around a 1.0 volt low voltage carrier supply! (LOGIC)
AGAIN ROUGHLY that would equate to a 20 rod ground system that I should have for my system to be viable.
However I am ONLY going to add the six more rods at this time and compare the improvement to my system as it operates at this time.
I ALREADY KNOW THAT THE EARTHS MAGNETIC FIELD VARIES GREATLY AT DIFFERENT POINTS ON THE GLOBE so don't
try to initiate that type of discussion with me because I won't answer you. that's WHY I said roughly!
Am looking forward to getting the 6 new rods completed and results tested -YES YES!
thanks and Cheers!
Clarence
Clarence
[quote author=Void link=
All the best...
[/quote]
Clarence:
just a quick info update:
I just finished the installation of the SIX new ground rods to be connected to the open ended circuit of
the previous EIGHT ground rods which will give me a new ground return circuit of 14 earth rods.
my wire to MAKE the connections wont be in until tomorrow afternoon so I will be working late to get that done!
So I wont be able to begin testing for new results until Tuesday morning!       that's life!!
Should be able to post some results by about noon Tuesday!
thanks and Cheers!
Clarence
Void
Sounds good Clarence. Will be interested to hear how you make out with
the expanded ground rod grid system.
All the best...
skribat
