Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 68 Guests are viewing this topic.
tesletic
Quote from: skribat on February 24, 2015, 03:09:23 AM
I think this will interest some of you .. EM, and government research
https://www.youtube.com/watch?v=_iMokLg9-eY#t=73
Thanks Scribat for reminding me as I know him for years as you can see on my (old) pages although never seen this interview ! http://view-tronics.com/mymindtwist/zpe.htm I agree with all the technical stuff he explains and he is sure far more intelligent then myself but then again what is ''intelligent'' LOL  ;D Some people confuse it with successful !  ;D  Anyway I absolutely do not agree with his ''governmental, patents etc'' solution as this will never work !? The ''RADIANT'' technology should be available to be build for all entities on this planet, meaning not being restricted or withhold by any person country or company.
Eventually what we are doing here is unstoppable for the powers that be because of the same facts like I wrote on my bike pages http://tesletic.view-tronics.com/projectinfo.htm When this really takes of the only way for them to get profit out of it is just make taxes on the roads and the air we breathe ! For example here in Spain you have to pay a tax if you use solar panels ! DUH yea I know unbelievable !   :o
Anyway this forum can make the difference that is for sure as I am waiting  impatiently for Clarence findings...and thank you all.  ;)
skribat
making you pay tax for collecting sunlight is IMMORAL, only an evil government would seek to deny a person's natural right to light. If it is like that now we must think how it might be if we permit AGENDA 21 and a Global government (World  dictatorship).
Clarence
Clarence:
Hello Void, a.king21, & ALL,
Have not been able to finish my connections as extreme cold ( VERY unusual here!) and rain has hampered my progress.
will make effort to finish to day and get some testing done.
Patience.
thanks - working on it.
Clarence
Clarence
Quote from: Clarence on February 25, 2015, 08:46:40 AM
Clarence:
Patience.
Clarence
Clarence:
Hello & All,
Have not finished readings and testing yet  but so as to not crowd too much info in one posting here is
some correct as I believe a GOOD 40 ground rod build should look like. and it is not anything as wild as the
40 rod system that B&L recommended. they said (supposedly) it covered a 30 METER by 50 METER area!
that is NOT realistic as far as the data I have in my personal computer ...WHICH IS ME!!...I have more data
stored inside me than my desktop computer has in it and it has over 1,000,000 files stored in it. anyway I KNOW that
most well known radiant energy people advocate a 2 meter space between ground rods which in USA terms MEANS 6 feet!!!!
I believe what B&L meant was FEET instead of METERS!
If you apply the 6 foot space rule to the 30 by 50 you come out with a 48 rod RETURN system and a 5 rod into ground system
which makes a hell of a lot more sense!
AND it takes up WAY less space to get the job done.
In the attachment you can drag one or both of the open end legs to the left or right of your property around either
side of your house as needed! just be sure to maintain the 6 foot space between rods and rows of rods.
Its that simple!
enough.
back to work.
thanks and cheers!
Clarence
Clarence
Clarence:
Hello @ ALL,
this posting is to be considered with my previous posting concerning the 40 to 48 ground rod GROUND GRID SYSTEM
layout I proposed at that time. after having completed hours of testing and evaluation of results I am more than ever SURE
its a GOOD layout to follow AND one that is actually needed to succeed.
I spent all of last night using every configuration that came to thought with all of the build components that you have seen plus.
first let me say that the LAST SIX RODS I placed this last week W E R E  an IMPROVEMENT!!!!
I had started off with just the 2 rod RETURN system from the earth but that only gave the capture circuit using the
ground leg as the circuit neutral leg an available voltage to load of 84-90 volts.  NO GOOD!
next I decided to use a circle pattern of 8 rods. but that many rods only gave a neutral leg voltage to load 0f 110.7 volts. NO GOOD!
I did some reasoning and figured I needed a total of around 20 rods. I decided to do 6 more rods and see. total of 14 rods.
this time it gave me a voltage to load of 113 volts. GOOD but NOT QUITE ENOUGH! I need to do 6 to nine more!!!
I am fairly sure this will give me the background potential needed to avoid any more voltage drop to load.
before I started testing I had problems with my Trip Litte PR30 power supply. when I would power the system up with
the batt array and then use the system circuit to start the power supply the heavy load surge would kill the inverter immediately!
the lower battery voltage and the surge was just more than my 1000 W inverter can handle! So I decided to try the PR15 unit I thought I had fried.
after it had cooled down back then it was still OK! I tried it but all it would do is just make the inverter PULSE on and off. so I decided to power it by
my house mains as I did last time I tested!!! when I powered it up and started the inverter with the battery and then flipped the switch
on the power supply it hummed slightly but would not put out any voltage. the power supply internal over voltage switch was fighting
against the battery voltage. I turned the battery off and all was well! That is WHY it overheated way back there
I plugged a kill-a-watt first and then an outlet array into the capture circuit and plugged the red 250 watt bulb into the circuit and it started to
pulse off and on so I said to self 250 watts load is to much. the voltage on the kill-a-watt at the inverter showed 115 volts+-.
so I plugged my small battery charger in for a start load and went ahead and hooked it up to the battery array since it was off.
next I plugged  a 36 watt CFL and the kill-a-watt I placed at the head of the circuit showed the voltage start to drop a little.
next I took my dremmel tool and hooked it into the circuit and turned it on wide open. the voltage on the capture kill-a-watt now showed 113 volts+-
at 204 watts. since I knew 250 watts was too much I stopped loading  and settled for the 204 watt load.  I also took the dremmel tool and tried to stop the
RPM but that did NOT happen and didn't bother the load voltage either. I let everything run as stated for 2 and 1/2 hours with no changes in voltages or watts
on the meters so I turned every thing off and stopped.
A GOOD improvement to my way of thinking. all in all it says the system does work!. I just need to meet the 20 rod pattern I previously figured on
plus a couple. also I know definitely that I need to up size my Inverter and I believe the PR15 can handle the load also.
also I need to tackle the problem of the power supply fighting the battery voltage................I can tell you how B&L DID IT!!!! when the problem came up for them
they simply switched to a UPS (uninteruptible power supply.............."NO-BREAK SYSTEM" as they called it). it did all the switching and monitoring for them
and has ALL the same components in it plus a capacitor and a few dedicated circuits and sensors! they put all THREE of the systems together for themselves
and came up with a winner!  1. UPS    2. Capture system   3. GROUND GRID SYSTEM .
NOTE: the ground grid lead DID show 1.8 amps and the capture loop went from 1.3 amps to 1.4 amps
            again that says things are working the way they should!
thanks and cheers
Im tired!
Clarence
