Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
mscoffman
All,
I have come up with a simplification equivalent for construction of the Captor transformer as used by Clarence. Please see
Clarence's Schematic two posts above this post. It should be easily possible to construct a full *300Watt* Captor transformer
using two 2 times new Weller D650 200/300 Watt Soldering Guns connected by small ID copper pipes, the guns pointing
tip to tip. I propose slipping the copper pipes over the nickel plated ferrules at the tips of the guns then soldering them
in place by swaging in the style of soldering copper water pipes. The use a harder higher temperature solder then normal
electronic circuits will insure that the joints will not come apart under moderate heating conditions. Use several dabs of
Silicone RTV sealant to prevent the copper pipes from shorting along their length. One would then add wiring to make sure
the trigger switches are wired into an always on position of the 300Watt setting as well as adding the flying wiring. Before
adding the flying wiring one could run a test that the unit forms a one to one .3KVA isolation transformer before proceeding.
I would suggest installing the ungainly unit on a piece of wooden back board and holding it in place with tie wraps around
the gun handles. Remove the small incandescent bulbs.
JBTOOLSALES.com - Weller D650 Solder Gun   -  $43.09  X times 2   =  Total $86.18USD
http://www.jbtoolsales.com/weller-d650-300-200-watts-120v-industrial-soldering-gun/?gclid=CLKm5r3JtMQCFS1o7Aod3C0AGw
This is untested because I don't have access to a compatible ground array, but it should work. This should make it easier for
beginners to construct the Captor transformer as no toroids or wire winding are involved.
:S:MarkSCoffman
Clarence
Quote from: Clarence on March 19, 2015, 12:29:32 AM
Clarence:
Hello Void & All,
I attached the new block schematic of my improved unit.
It will remain in this form for a long time As it is very simple! It has way less components and is therefore more cost effective!
It also Has produced a unit that IS SELF POWERING!!!!!!
at present I have found out today that my present 20 rod return grid is not cutting it! I have 10 more rods coming in tomorrow and
I will be installing these soon to bring my rod total to 30. after that I will test and post some info about both the components ID and
where to get them, etc.
I will get into the self powering aspect later also. for now just KNOW THAT IT IS VALID!
thanks and cheers!
Clarence
Clarence:
Hello Void and ALL,
I Have 5 of the ten new rods in and connected so far but I have been BUSY with all the spring to-dos so
that my time has been limited. will finish the other five rods and connections tomorrow.
I have finally taken photos of my completed  built and have attached an appropriate photo that shows an overview.
it also shows the heat lamp working.
today I also powered the unit (minus the charger - battery - inverter ) by mains power as B&L demonstrated when
they did the 6000Watt lights.
the results were STUNNING TO SAY THE LEAST!!  more on that later. I do believe it is going to be necessary for
me to go the full forty rod lay out to achieve a full constant 120v - 122v  rms voltage under several loads at a time.
today I DID run my microwave on high for 1 minute intervals several times and vaporized the water I had in a jar!
more on that later also.
just really wanted to post so that you wouldn't think I fell off the earth.
Cheers
Clarence
Void
Hi Clarence. Thanks for the update on your progress and latest testing.
That's a nice professional looking layout as well. Good work!
All the best...
turbogt16v
Void
Quote from: turbogt16v on March 24, 2015, 08:56:15 AM
ok ,did any of you read what is Marc Belanger commenting in this video
Hi turbogt16v. Yes, that is a given. That is why the only valid test of this sort of device which relies
on an earth ground is to power it from a battery and use an inverter. If you have the mains connected in
there in any way there is always the possibility of an earth ground loop.
All the best...
