Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 129 Guests are viewing this topic.
Clarence
Quote from: a.king21 on April 03, 2015, 04:14:40 AM
Clarence:  re Void's and Hoppy's  comments.
There is one thing you have to watch out for.
Most inverters DO NOT have an isolation transformer between battery input and mains output.
This means that if you plug into your  household appliances, you have to make sure that they are independent of your house mains. IF you simply hook your inverter into your mains wiring, it will cause a ground loop with your grounding rods.
I know because I inadvertently looped my inverter in  one experiment.
Anyway congratulations, and remember, that having gotten this far, you are bound to get more attention from the community.
Hello a.King21,
whenever I use one of my household appliances as a test load it is totally unplugged from ANY source of mains all together!
my unit is not connected in ANY way to a mains source and never will be FOREVER! with the completion of all of my new ground rods
any need  for such a connection totally vaporized!!!  and will remain that way!
I understand what you are saying completely AND I DO APPRECIATE your concern AND support. we go forward together in like minds.
Thanks again and cheers!
Clarence
ramset
Clarence
I had not realized you are completely running off grid with these setups.
You have given me a great pause to think about  past experiences which I disregarded as mistakes.
thank you for all you are doing, I am quite close to the supplier in CT and will be
collecting the bits and pieces for a replication.
Thank you
Chetkremens@gmail.com
Thanks Grandma
Clarence
Quote from: wistiti on April 03, 2015, 01:21:53 AM
Hi Clarence!
Strange they dont understand you run it completly out of the grid... Only with a 12v lead acid battery and a 120vac inverter ...!
Anyway, i have (again) some question!
With the setup you have now (near 60 ground rods) when it is running in loop , what is the max load you can put on it?
Other question, the ground "captor" seem to be the key. But do you think we must have a high power inverter or just adding ground rod will be find? (Meen nead 100w inverter to drive 100 w load + selfloop or we can drive bigger load than the "inverter driving part" is rathing for??)
Again, thank you!
Hello Wistiti,
when I have adapted the unit to 120/240 volt mode I expect a 12 KW load usage or larger. time will tell.
as I see it you need a fairly large inverter to assist in implementing the voltage from the earth along with the amperage supplied through the
captor loop to power loads. I would expect the ratio to be somewhere around  80/20,  earth/captor : inverter.
again time will tell and the OU community will have the answer as well. that's what I keep working towards and for my personal use as a first.
The whole world keeps looking for free energy! actually there's no such thing!
my unit , with rods and all components wasn't free at all . it cost money AND a hell of a lot of effort and TIME. the components wont last forever
so there will be up keep to consider over time also!
its called LIFE and it keeps ticking along with OR without us!!  HA! HA!
thanks and cheers!
Clarence
Hoppy
Quote from: Clarence on April 03, 2015, 05:05:53 AM
Hello a.King21,
Clarence
Clarence,
You say you are running completely off the mains (no connection to live or neutral). What ampere rating are your batteries that power your inverter?
Enjoykin
If there is no such thing  "free energy" - why than so many brilliant researchers and inventions were killed by oil-barons mafia ??  8) List of names is so long......
I bet - next oil-barons move will be "Copper Rod Bill" for every copper rod pricked in ground.  8)
and than "Sun Bill" for every Sun Ray Light......  8)
