Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Clarence
Quote from: cheors on April 05, 2015, 03:45:24 PM
@ Clarence
Back to the toroids wiring:
I understand that they are identically wired : primaries in phase and secondaries also  in phase. Right ?
Theorically the output current should be null.
You get 1.3A because components are not ideal (number of turns, ferrite  compound , ...)
If i forget the 10 AWG "polarizing" wire connected to one side of the secondaries.
OK  or i have missed something ?
Hello cheors,
it is still the same as I told void in my previous post to him. take ALL of the theoretical ideas in your head -rip them out-and
set them aside for awhile or they will just keep defeating you.
also you are still trying to"JUMP AHEAD" so to speak , without doing anything.
like I told void, you get TWO feritte toroids with primaries only and then YOU wind the secondaries as I have shown in photos  I have
posted before, exactly as shown ( stop trying to guess about something), and then connect them exactly as have SAID to do it and then
post a photo of your completed CAPTOR LOOP assembly and THEN I will explain in detail WHY it works AND HOW it works......but
NOT until you do YOUR PART!!!!
I am simply NOT knowingly going to let any one take a short cut!!!!!!
the first one that completes the simple Captor loop set up and sends an ACTUAL photo of it completed will get to be LEADER OF THE PACK
for a change. and I already KNOW they are going to be Spitting out result values like pennies because they have tried it!!!
My advise is to also get one of the KILL-A-WATT meters to put in between the mains and the primaries of the toroids.
they are SO easy to use to see what you are doing. just a FINGER TOUCH ACTION. delightful!
Thanks and cheers!
Clarence
nelsonrochaa
Quote from: Enjoykin on April 05, 2015, 02:56:11 PM
Hey nelsonrochaa !! :D
I was watching many your videos and i think you are great researcher and smart man which think with own mind. I like your quality for sure !!
About likes and dislikes - solve the problem with easy. Just inhibit comments. Put a link/s on file/s and site/s. Will be enough. Who want to take informations he will -  trolls sure will not.
Use OU-principle - Take it or leave it.
ps: people usually work like PID controllers.  If the some system is lot sensitive to feedback - they will do everything to make the system out of work. Simple your reactions are feedback for them. Solver is simple: take control over the feedback and filter all like PID controllers do.  :D
Reg.
Enjoykin
Hi Enjoykin,
Thanks for the tip ,  and for compliment.
If i put fakes all people will like and put positive vote, but i don't lie in anything that i show the people dislike  lol.
The ignorance can blind people .
wish Luck for everyone.
tinman
Quote from: Clarence on April 05, 2015, 05:43:18 PM
Clarence
Quotetake ALL of the theoretical ideas in your head -rip them out-and
Thats tha ticket-throw out all common sense before continuing with this project :D
Quotelike I told void, you get TWO feritte toroids with primaries only and then YOU wind the secondaries as I have shown in photos  I have
And so it begin's-->Yes-go spend your money,and use your time to build a device that the inventor refuses to explain or show working until you do so.This is where you throw out common sense-->this is where you pay for your new car before you even know if it runs or not-->even the salesman refuses to start it for you.
Quotethe first one that completes the simple Captor loop set up and sends an ACTUAL photo of it completed will get to be LEADER OF THE PACK
This is where the leader of the pack must know he has the rest of the sheep following him,and doing what he says before you get to eat that nice green grass in the next paddock.
This is your chance to a claim to fame.
Quoteand I already KNOW they are going to be Spitting out result values like pennies because they have tried it!!!
Well i dont know about spitting out result's,but you will certainly be saying goodbye to some pennies.
QuoteMy advise is to also get one of the KILL-A-WATT meters to put in between the mains and the primaries of the toroids.
You will also need a hydrometer to measure the pacific gravity value in your battery,as the most accurate and direct way to test the state of charge of a battery cell is to determine the specific gravity of the battery electrolyte,as floating voltage of a battery is no measure of stored energy within that battery.
You will also need a 3 or 4 channel scope that has simultaneous voltage and current waveform acquisition capability along with analysis functions.You can also use the NI PXI-4070 FlexDMM along with NI LabVIEW analysis function software. This is to measure the reactive power value that Clarence's meters will be missing.
So to bring back some of that common sense,you must ask yourself these questions.
1-Why do you have to use ferrite core toroids at these low frequencies?
2-Why dose Clarence insist that you buy and build before he has shown any sort of measurements of P/in and P/out?.
3-Why dose he refuse to explain or even do a loaded run for a couple of hours before you go and spend your cash,and use your time to build the device?.
What the hell,i have some cash to burn-->im going to build this wonder device.
Chet,i'll be in touch soon-may need some !!ferrite!! toroids if i cant locate them here in OZ.
https://www.sleepio.com/articles/sleep-science/what-happens-if-a-person-does-not-sleep/
cheors
If you really want to share with us : explain, first and show your device running ,two.
I don't understand why you want that people replicate without sufficient informations.
I have not enough money to start copying without a very well undestanding of how it works.
Cheers
skribat
what you need to understand, and young people often don't, Clarence is a wise old man, I also am an old man ..  he wants people to know how to plant the potaoes, .. not just to be there to put them in their baskets after he has dug them out of the ground.  you have to build on foundations, it also sorts out those who will commit themselves from the 'here today gone tomorrow' guys.  ..  There are lots of young kids out there talking hot rods, fuel injection and nitrous and they don't now how to change a fuel pump .. it's just time wasting and the older we get the less time we have to waste.
I'm a sceptic, but .. procrastinatiing doesn't get the job done.  .. either do it or don't do it, sometimes you have to take chances ..  and the guy who never made a mistake never made anything.  Clarence isn't forcing anyone,  if you want a shot at the lotto you buy a ticket.
